Posted: Fri Mar 04, 2011 4:25 am |
I think it might be that the sender is stuck, as it was working before I ran out of fuel.
How can I unstick it?
Posted: Fri Mar 04, 2011 6:39 am |
the leveler/ fuel sensor is on the fuel pump housing, which is under the rear seat(driver side)
Posted: Fri Mar 04, 2011 7:04 am |
I have no idea what it looks like or how to tell its stuck :S How do i fix it?
Posted: Fri Mar 04, 2011 7:11 am |
Lift the back seat up, see the big black plastic bung, thump around that hard a few times & see if that shakes the fuel gauge back in to operation.
Posted: Fri Mar 04, 2011 8:32 am |
Thanks, I'll give that a go
Posted: Fri May 13, 2011 8:49 am |
Mine stopped working, it was the connector plug pins that were corroded. Just cleaned them with emery and now works fine. A new sender unit is 95 quid from peugeot dealer.
Posted: Fri May 13, 2011 9:34 am |
Try filling it up and ragging it over speedbumps
Posted: Fri May 13, 2011 10:42 am |
wow, old thread
mine was just because the needle was pushed in too far and rubbing on the dials lol
Posted: Fri May 13, 2011 2:16 pm |
Abzynthe wrote: |
I have no idea what it looks like or how to tell its stuck :S How do i fix it? | An easy way to verify fuel sender sending correct signal.get access to pump and disconnect plug youll see 4 pins. 2 of them are smaller.they are fuel sender output.using an ohmmeter measure the resistance between two small pins.when tank is full it should be around 50 ohms and when empty it should be 350 ohms.when you fill the tank or move the floater resistance must decrease smoothly(not jumping) from 350 to 50(full).
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
