Latest: DanDan17
Overall: 17128
Online Now [58]:
Visitors: 57
Today: 12688
Total: 100440403
Forums › The Car › 206 Problems › Fuel gauge doesnt work
Abzynthe
PostPosted: Fri Mar 04, 2011 4:25 am Up
East Area Rep - Abzynthe
I think it might be that the sender is stuck, as it was working before I ran out of fuel.
How can I unstick it?
PostPosted: Fri Mar 04, 2011 6:39 am Up
the leveler/ fuel sensor is on the fuel pump housing, which is under the rear seat(driver side)
Abzynthe
PostPosted: Fri Mar 04, 2011 7:04 am Up
Thanks Smile
I have no idea what it looks like or how to tell its stuck :S How do i fix it?
PostPosted: Fri Mar 04, 2011 7:11 am Up
Lift the back seat up, see the big black plastic bung, thump around that hard a few times & see if that shakes the fuel gauge back in to operation.
Abzynthe
PostPosted: Fri Mar 04, 2011 8:32 am Up
Thanks, I'll give that a go Smile
jif63
PostPosted: Fri May 13, 2011 8:49 am Up
Mine stopped working, it was the connector plug pins that were corroded. Just cleaned them with emery and now works fine. A new sender unit is 95 quid from peugeot dealer.
206 1.4 diesel
kieron
PostPosted: Fri May 13, 2011 9:34 am Up
Try filling it up and ragging it over speedbumps Smile
Account suspended
Abzynthe
PostPosted: Fri May 13, 2011 10:42 am Up
wow, old thread Razz
mine was just because the needle was pushed in too far and rubbing on the dials lol
elcamino
PostPosted: Fri May 13, 2011 2:16 pm Up
Abzynthe wrote:
Thanks Smile
An easy way to verify fuel sender sending correct signal.get access to pump and disconnect plug youll see 4 pins. 2 of them are smaller.they are fuel sender output.using an ohmmeter measure the resistance between two small pins.when tank is full it should be around 50 ohms and when empty it should be 350 ohms.when you fill the tank or move the floater resistance must decrease smoothly(not jumping) from 350 to 50(full).
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
