Latest: DanDan17
Overall: 17128
Online Now [53]:
Visitors: 52
Today: 7475
Total: 100435199
Forums › The Car › 206 Problems › ignition barell
ignition barell
gaffy
PostPosted: Fri May 13, 2011 2:58 pm Up
hi everyone, my barell is on its last legs, the spring has broken inside, now im having to pull the key back as if the spring is working, an sometimes the key gets jammed awsell which is really annoying!! can anyone give me any advice on how to change it? my car is 2000 gti thanks Very Happy
chin up lad
PostPosted: Fri May 13, 2011 3:14 pm Up
Tryed wd40 in the barrel??
U could Search eBay for lock barrels and keys, people sell full sets, I just got a full set for £30 posted including petrol cap barrel,
To change the ignition barrel it self u need to remove all the plastic around it, unplug from fuse box, undo the torx screw on top, put key Im and turn it and then pull it out,
gaffy
PostPosted: Fri May 13, 2011 3:33 pm Up
hi northants ben, thanks for your repley, is it just a case of getting a new barell an key an swapping over? what about the fob, do i just open it an put the new blade in?
chin up lad
PostPosted: Fri May 13, 2011 3:39 pm Up
need to rember the key blade you have now also does the doors and petrol cap so thats why i brought a full set from ebay,
to change the blade in fob on mine i just undo the little screw on the key fob, pull blade out, push new one in and put screw back in,
there are probably other ways to this but this is how i went about it other week, just gives you an option,
gaffy
PostPosted: Fri May 13, 2011 3:44 pm Up
ahh thanks for your help Very Happy shall get onto flea bay asap thanks
chin up lad
Just go to a Pug main dealer with the V5C log book & photo id, then order up a new barrel to match your original key.
PostPosted: Fri May 13, 2011 3:46 pm Up
out of interest u know how much is it?
i needed door locks and petrol cap, thats why i went for used parts.
PostPosted: Fri May 13, 2011 3:53 pm Up
Depends on if the car is non plexed or plexed as the part numbers are different.
gaffy
PostPosted: Fri May 13, 2011 3:58 pm Up
hello mr bsi my gti is a w plate yr 2000 so its non plexed?
chin up lad
