Posted: Fri Mar 04, 2011 5:34 pm |
Right so i need to replace it.. I think ive located it, any chance someone can confirm where it is to make sure.. Also it looks to be a b*****d to remove.. Any tips?
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Fri Mar 04, 2011 5:39 pm |
if its the one thats in all the plastic housing for the water on the end of the engine above the gear box then i think its just a clip that holds it in.
Posted: Fri Mar 04, 2011 5:45 pm |
I had a look at the haynes manual... But i couldnt work out where it was saying..
Posted: Fri Mar 04, 2011 5:58 pm |
Just looked on servcebox and it seems to be located in the thermostat/coolant housing on the right hand side of the cylinder head. Couple of diagrams showing location of it in both the plastic housing and also aluminium housing depending on which you have. Number 9 is the temp sensor.
hope that helps.
Posted: Fri Mar 04, 2011 6:10 pm |
if its the plastic type, number 11 is the clip that just slides out and the temp sensor pulls out after a wiggle as the clip just holds the sensor in against a rubber seal.
Posted: Tue Mar 08, 2011 8:53 am |
Yea thats what i though.. Looks like a right b*****d compared to my old 1.4 :S
