Forums › The Car › 206 Problems › Clutch has gone I think... |
Posted: Sat Mar 05, 2011 1:42 pm |
Hi all
Well on my way to Southampton heading for my nearest Powerflow for some exhuast work, the car started over reving whilst trying to gain speed. I could sit in 3rd with my foot to the floor revs around 4k and only be doing 30, it continued there and back, but whislt at Powerflow I spoke to the guy about the problem, and he thought it'd be the clutch, I thought it was either the clutch or the gearbox anyways so it confirmed what I was thinking.
Now I'm not looking for a cheap kit that'll just about make the car move, but a decent kit for a reasonable sum of money, so if anyone could recomend one that'd be great:)
Had a quick look around KamRacing and they have this www.kamracing.co.uk/in...-disc.html what is the difference between a rigid disc and a normal one?
Cheers
Ryan
Posted: Sat Mar 05, 2011 1:44 pm |
sorry cant help with your problem but would just like to say.. Ste206's text correction fail on sum
Posted: Sat Mar 05, 2011 1:46 pm |
Just get a standard clutch from Euro Car Parts or similar.
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
Posted: Sat Mar 05, 2011 5:02 pm |
don't buy transmech, they are poorly build.
get the valeo clutch kit. though is more expensive (nearly double the price) but it worth the extra
Posted: Sat Mar 05, 2011 5:31 pm |
Seabook wrote: |
get the valeo clutch kit. though is more expensive (nearly double the price) but it worth the extra |
Thanks for the replies guys, yeah I was thinking about the valeo one but there wasn't much difference in info between the two so was unsure, but that has cleared that up:)
