Posted: Mon Mar 07, 2011 1:30 pm |
hi all, have a problem with my central locking bouncing. ive disconected each solinoid indvidualy and it still bounces etc only way i can lock is manually but then it still bounces at times getting fed up with leaving boot open continously as car is still well under project stage with many tools left inside. any ideas as what to do ? thanks in advance for your opinions and advice
Posted: Mon Mar 07, 2011 1:33 pm |
probably a door sensor gone or something but im not too sure so just thought i would put it out there
Posted: Mon Mar 07, 2011 1:34 pm |
how i go about checking them then
Posted: Mon Mar 07, 2011 1:43 pm |
Possably the door actuator mate. Same happened to me. It's a pig to get to. But simple enough to replace.
Posted: Mon Mar 07, 2011 1:47 pm |
AsphericSmile wrote: |
Possably the door actuator mate. Same happened to me. It's a pig to get to. But simple enough to replace. |
anyway of checking and what sort of price we looking at for a new one
Posted: Mon Mar 07, 2011 1:48 pm |
liambez wrote: |
what sort of price we looking at for a new one |
No idea until you give us some clue what type of 206 we are dealing with as they aint all the same
Year?
Normal locking or deadlocking?
Tbh mate I wouldn't be able to tell you how to check. I only knew because I took it to an auto electrics garage. They told me the problem and I sorted it myself. They wanted about £150 to sort it inc. parts and labour for atleast an hour.
I did it in 10 mins for about £30.
Posted: Mon Mar 07, 2011 1:53 pm |
MrBSI wrote: |
liambez wrote: |
Year?
Normal locking or deadlocking? |
its a x plate so 2000 model 3 door single locking mate
Posted: Mon Mar 07, 2011 1:58 pm |
I see Peugeot have put the prices up for the lock motors
I remember when they used to be under £30 for simple central locking, not any more
Gonna be a scarpyard / Ebay / car breaking on here job once you find out which one it is causing the problem.
Posted: Mon Mar 07, 2011 2:02 pm |
MrBSI wrote: |
Gonna be a scarpyard / Ebay / car breaking on here job once you find out which one it is causing the problem. |
any ideas on how to check ?
Posted: Mon Mar 07, 2011 2:03 pm |
Plug Peugeot Planet in & see what fault's the BSI throw's up.
Posted: Mon Mar 07, 2011 2:17 pm |
MrBSI wrote: |
Plug Peugeot Planet in & see what fault's the BSI throw's up. |
would love to but dont have the software or cables for it and the car is not drivable as no MOT or tax so cant drive to get it done either. any more ideas ?
Posted: Mon Mar 07, 2011 3:33 pm |
i had same probably, u can still lock the boot mate manually
| .. Peugeot 206 2.0 D turbo hdi .. | |
Posted: Mon Mar 07, 2011 3:34 pm |
take the black cover off the boot, and there will b a little bar just push it across
Posted: Mon Mar 07, 2011 4:54 pm |
I had the same probably but luckily had a 206 i was scrapping. I had to change the central locking unit inside the door. White thing with a couple of wire bars like coat hangers coming off them. lol. I don't know if there is a way of checking which one is faulty but I just changed both. They're a pig to remove/change tho. I know where there is a 206 being scrapped. If you are interested pm me and i will pm u there tel no and you can ask how much they want for them. Sorry don't know the proper name 4 them.
