Online Now [179]:
Visitors: 179
Today: 34191
Total: 116841088
Forums › The Car › 206 Problems › Seized caliper
Seized caliper
sicskate
PostPosted: Sun Mar 06, 2011 5:57 am Up
Trade Rating: +13
Looks as if my front caliper on my gti is seized.
Anyone know how to release the piston, or should I just replace the caliper?
Many thanks
Ben
307 1.4hdi Smile
no_offences
PostPosted: Sun Mar 06, 2011 6:03 am Up
if you decide to replace i have some for sale
Signature removed due to size
sicskate
PostPosted: Sun Mar 06, 2011 6:16 am Up
Trade Rating: +13
I'd like to free my piston up before I go buying parts.
307 1.4hdi Smile
no_offences
PostPosted: Sun Mar 06, 2011 6:27 am Up
tbh tho if its seizing that is usually a sign its f****d lol
PostPosted: Sun Mar 06, 2011 6:51 am Up
Depends on what bit is seized up.
If the piston is seized then replace the caliper, if its just the sliders then clean / lube them up.
panason1c
PostPosted: Sun Mar 06, 2011 9:41 am Up
Remove the brake pads and refit the caliper without the pads and the have someone push the brake pedal with enough force that the piston begins to move ............then, with foot OFF the brake pedal, lever the piston back into the caliper........keep repeating until the piston moves back and forth freely.
Try to avoid the piston popping out of the caliper, but if it does just clean up the caliper bore with 600 (or finer) wet and dry paper, refit and bleed the brakes.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
sicskate
PostPosted: Sun Mar 06, 2011 12:28 pm Up
Trade Rating: +13
Ok guys, I managed to free it up using the how to guide.
I was inspecting my calipers on my 2000 gti and strangely my calipers opened upwards?!?
The 13mm bolt was on the bottom instead of the top...
I'm wondering if the calipers have been swapped?
307 1.4hdi Smile
PostPosted: Mon Mar 07, 2011 4:26 am Up
There are 13mm nuts top & bottom, so they could hinge either way.
