Posted: Fri Mar 04, 2011 2:13 pm |
Ive played about with my fuel gauge and now thats working, but the mileage counter isnt
The ribbon at the back has a crease in it but doesnt look broken.
any ideas?
Posted: Fri Mar 04, 2011 2:45 pm |
The crease could be the cause tbh, there pretty brittle with age and even a crease can cause them to no longer work, can you not source a new part inc a ribbon and replace the creased one?
IIRC they're soldered onto the board, but aslong as your half decent with a solder iron it's a simple enough job
Failing that, if you cant fix it get a new one and I'll have to come to a meet in Peterborough some time and solder it for you lols
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Fri Mar 04, 2011 2:57 pm |
ah that dont sound too bad then, ill have to get it sorted, before June (MOT time) lol
Posted: Fri Mar 04, 2011 6:20 pm |
If its only the mileage counter (odometer) that isnt working then dont worry about fixing it for the mot as its not an mot test item.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Tue Mar 08, 2011 1:34 pm |
You need a mileage recorded on MOT though dont you?
Posted: Tue Mar 08, 2011 1:37 pm |
Abzynthe wrote: |
You need a mileage recorded on MOT though dont you? |
Thats exactly what i thought as it goes down on the doccumentation
Posted: Tue Mar 08, 2011 1:42 pm |
My ribbon broke, I changed the dials over and the guy said I needed to have a milage to record so I had to put in salvaged clocks so my MOT certificate says 76 thou instead of 43. I need to find some one who could help my repair it, I can find new clocks at the scrappy all day long, just no idea how to repair it
Posted: Tue Mar 08, 2011 1:43 pm |
does it matter if the mileage is lower than the last recorded mileage? If not, then i can just get a crappy set to put in for the MOT, as i dont fancy re-glueing my plasma dials.
Posted: Tue Mar 08, 2011 1:45 pm |
well mine says 30k on the mot certificates, when old ones say 80k so wouldnt of thought so
Posted: Tue Mar 08, 2011 1:59 pm |
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Tue Mar 08, 2011 2:22 pm |
Abzynthe wrote: |
Yes, its recorded on the mot certificate but it's of no concern to the mot tester, or the authorities if its the exact same mileage recorded at every mot!
BMW K1200RS | |
Posted: Tue Mar 08, 2011 2:38 pm |
hmm, might just put a post it on the cluster before the MOT then lol.
