Latest: jtq4u
Overall: 17141
Online Now [271]:
Visitors: 270
Today: 46403
Total: 113953440
Forums › The Car › 206 Problems › Handbrake Cable
Handbrake Cable
liambez
PostPosted: Thu Mar 10, 2011 10:35 am Up
I believe on these car there are 2 handbrake cables and not just one am i correct in saying that ? also i need to replace it if it is 2 should i replace both or just the one ? thanks for any help.
Also if you know any places around lincoln to get Cheap parts from Please let me know. thanks in advance liam
pug 206 1.4 project car
PostPosted: Thu Mar 10, 2011 10:38 am Up
Disc or drum on the back as the cables are different.
It does help if you give some information when asking for help Wink
liambez
PostPosted: Thu Mar 10, 2011 10:39 am Up
Lol sorry mate its drum brakes
PostPosted: Thu Mar 10, 2011 10:44 am Up
Peugeot / Citroen part number is 4745 N4 Handbrake cable & there a wallet busting £16.61 including VAT each.
There's a pair of cables fitted, there both the same part number, one goes to each rear brake.
FYI: The cable for rear drum brakes is shorter then the one used for rear discs Wink
liambez
PostPosted: Thu Mar 10, 2011 10:47 am Up
ah spot on mate would u recomened replacing them both then or just the one ?
PostPosted: Thu Mar 10, 2011 10:50 am Up
I'd do both on my own car but its up to you & whats in your wallet.
liambez
PostPosted: Thu Mar 10, 2011 10:57 am Up
personaly i think ill have to replace both and its probably best to due to the fact the car has been stood for the last 2 years
A18NHH
PostPosted: Thu Mar 10, 2011 11:12 am Up
do both - for the £16 extra it's worth it
Wahoo!
