Latest: Makomeister18274
Overall: 17122
Online Now [210]:
Visitors: 209
Today: 18127
Total: 97766055
Forums › The Car › 206 Talk › Question about spraying, im confused
PostPosted: Wed Mar 09, 2011 8:28 am Up
Right ive just been out and bought some proper paint for my car which was made up and i was told it wont need laquer on top as it has a gloss finish anyway so do i need to wet n dry it after its 3rd coat of the paint or not, i want the best finish as possible.
Is it better to wet the sandpaper or have it dry for keying before paint?
Thanks, just confused
PostPosted: Wed Mar 09, 2011 8:30 am Up
Is it for inside or outside the car?
Jayde
PostPosted: Wed Mar 09, 2011 8:34 am Up
I'd probably lacquer it lightly anyway for abit of protection
Man the F--- up!
PostPosted: Wed Mar 09, 2011 8:36 am Up
Outside and some bits inside, but the guy said thatit wont need any and this is coming from a professional car spraying shop
kieron
Im in the middle of painting a panal on my scooter at the moment, i have followed this
www.206info.co.uk/Foru...81546.html
and this is the results using halfords paint
Account suspended
NICKST
If it's solid colour or high gloss then only give it a light de nibing after you have finished painting and it's fully dry but you will need a compound like g3 to bring the colour back up. If there is no dirt in the paint when you finished dont bother sanding and buffing it.
PostPosted: Wed Mar 09, 2011 8:39 am Up
Surely laqeur gives it it's hard protection coat?
PostPosted: Wed Mar 09, 2011 8:41 am Up
A lot of solid colours aren't lacquered, they just add something to the paint.
Thats why you can get something sprayed in a solid colour in a day Smile
Jayde
Agreed. At least tha'ts what I've been told with the vehicle paint I'm using
Man the F--- up!
PostPosted: Wed Mar 09, 2011 8:42 am Up
Yeah i was following same steps aswell but went to the shop and they just said i wouldnt need it?
If it has any nibs Nick do i use the sand paper wet or dry?
Yeah i thought the laquer hardernd the paint and protected it
PostPosted: Wed Mar 09, 2011 8:43 am Up
Ahh right, so i dont need to add laquer once sprayeed because it already has some sort of it contained in the paint then
PostPosted: Wed Mar 09, 2011 8:54 am Up
Don't wet sand paper as it will fall to bits. If you're using "wet or dry" paper, I always use it wet. reduces dust and helps the paper glide over the surface, and helps reduce clogging.
PostPosted: Wed Mar 09, 2011 8:59 am Up
Yeah im using the wet n dry paper so wet that and it will work fine?
Not sure if its the same for rattle can. Was my mate who's a sprayer that told me
PostPosted: Wed Mar 09, 2011 9:02 am Up
ill just give it a shot then and see what the results are like, anything has got to be better than my matt black rear lights lol
