Online Now [97]:
Visitors: 96
Today: 31356
Total: 139781825
Forums › The Car › 206 Problems › radiator leak
radiator leak
Kersh
PostPosted: Wed Mar 09, 2011 1:34 pm Up
Cracked open the bonnet today and noticed a large amount of white splats all over the place from the radiator backwards, was pretty obvious that it was water and the antifreeze had left white marks.
Had an inspection of the radiator and noticed that under the pipe thats just to the right of the centre of the radiator connected to the header tank is where it seems to be coming from, the pipe itself seems fine, no splts or anyhting and wont move when i tried to budge it.
the mesh on the top of the radiator itself howver had come away from the radiator by a couple of mm just in that area. and i could still see a couple of bubbles just under that mesh.
now could it be that mesh coming away thats caused the leak or is it just bubbling because its collected in there from a header tank leak etc.
how is the header tank connected to the rad?? it could be coming from there.
and if it is the rad.. whos got one for sale? Very Happy
Member number: 36
LittleMiss
PostPosted: Wed Mar 09, 2011 2:04 pm Up
ive got one that will fit, 25 plus 10 postage. if it was the header tank the leak would either come from the tnk located near the bulk head or one of the pipes comes from it.
Will Update
Kersh
PostPosted: Wed Mar 09, 2011 2:07 pm Up
what condition is it in etc etc?? and itll fit a 2001 GTi 138??
Member number: 36
bellevuespares
PostPosted: Wed Mar 09, 2011 5:29 pm Up
Yes it came from a year 2000 GTi. Mint Condition
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
bellevuespares
PostPosted: Wed Mar 09, 2011 5:30 pm Up
Should explain, Little Miss is my wife...... So dont get confused.
Kersh
PostPosted: Thu Mar 10, 2011 3:41 am Up
aha fair enough! i will PM you then Smile
Member number: 36
