Posted: Mon Mar 14, 2011 4:47 am |
Harry wrote: |
I honestly don't know enough to tell you that, apart from brakes, engine Inc manifold, bsi, ecu i don't know if anything else is essentially needed |
the key
Posted: Mon Mar 14, 2011 4:59 am |
And the transponder ring now you mention it
Posted: Mon Mar 14, 2011 5:14 am |
Harry wrote: |
And the transponder ring now you mention it |
you have a pm bro .
Posted: Mon Mar 14, 2011 5:25 am |
Do you need the transponder key.....? They are universal and aint specific
You need a complete GTi wiring loom, front to back
Engine
Box
Subframe
Hubs
Driveshafts
Clocks
ECU
BSI
Key
Peddle Box
Just a little, food for thought
| Team Impossible Possible
Posted: Mon Mar 14, 2011 5:37 am |
I heard you need the transponder ring along with the chip from the key otherwise you will get the immobiliser fault and the engine won't start.
Posted: Mon Mar 14, 2011 5:38 am |
Addaz wrote: |
Engine
Box
Subframe
Hubs
Driveshafts
Clocks
ECU
BSI
Key
Peddle Box
Just a little, food for thought |
cheers bro
