Online Now [1148]:
Visitors: 1148
Today: 179755
Total: 151028639
Forums › The Car › 206 Problems › 'Cluncking' when turn Steering Wheel
A18NHH
PostPosted: Mon Feb 14, 2011 2:24 pm Up
as title, i had the radio off and noticed when i was parking and turned the steering wheel there was a 'clunk'
not too loud but enough to know it isn't right - i only seems to be noticable at low speeds though
any ideas? its a 206 GTi 2002
Wahoo!
Nelly180
PostPosted: Mon Feb 14, 2011 2:32 pm Up
onI have the same problem on my 180 mate. Was told it was the drive shaft joints knackered but when it went to the garage, they said there was nothing wrong with them. Still dont know what the noise is. Am guessing it can only be the steering rack.
They could of made it 200bhp!!
PostPosted: Mon Feb 14, 2011 2:34 pm Up
If it does it stood still could look into topmount bearings Wink
eddrj
PostPosted: Mon Feb 14, 2011 2:38 pm Up
yeah top mounts, i had this not long ago.
Old car 2000/ 206 2.0 hdi.
A18NHH
it does do it when stood still Very Happy
Wahoo!
troy
PostPosted: Mon Feb 14, 2011 2:42 pm Up
check the spring on each front side havnt snapped.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
meady
PostPosted: Mon Feb 14, 2011 3:06 pm Up
Trade Rating: +45
will either be top mount bearing or the droplinks, both quite a cheap fix if i remeber correctly
TEAM - I HATE FACEBOOK Smile
A18NHH
PostPosted: Mon Feb 14, 2011 3:07 pm Up
good Smile
i changed to drop links not long ago so i'll check they are tight and okay - failing that i'll do top mount bearing - thank god both only look like a £20 parts jobb Very Happy
Wahoo!
A18NHH
PostPosted: Mon Feb 14, 2011 3:12 pm Up
can you change just the bearing or do you need to change the whole top mount?
Wahoo!
PostPosted: Mon Feb 14, 2011 3:54 pm Up
Can change just the bearings on there own.
A18NHH
PostPosted: Sat Mar 19, 2011 5:01 pm Up
for information it was the top mount bearing - now repired Very Happy
£45 labour and £10 part
Wahoo!
PostPosted: Sat Mar 19, 2011 6:52 pm Up
Glad it's sorted Smile
PostPosted: Sat Mar 19, 2011 7:18 pm Up
lol
don't use cheap top mount bearing..... i manage to destroy 2 set of cheap top mount bearing in 3 months.....
peugeot top mount bearing is the only way to go
