Posted: Wed Mar 16, 2011 2:13 pm |
weres the bolt on the gti180 gearbox to put oil into it,
i leaked some oil when i was changing the shocks,one of the drive shafts popped out,,
if there's any pic that would be better..
thanks
Posted: Wed Mar 16, 2011 2:16 pm |
Posted: Wed Mar 16, 2011 2:19 pm |
Good lad
Posted: Wed Mar 16, 2011 3:06 pm |
thanks for the reply
Posted: Wed Mar 16, 2011 3:08 pm |
You dont fill it that way?
Use the reverse sensor hole
| Team Impossible Possible
Posted: Wed Mar 16, 2011 3:10 pm |
Addaz wrote: |
Use the reverse sensor hole |
Bodger. Do it properly.
Posted: Wed Mar 16, 2011 3:51 pm |
Edward wrote: |
Addaz wrote: |
Bodger. Do it properly. |
There's a fill / level plug on the end case of the gearbox for a reason.
