Latest: sparrowdclxvi
Overall: 17139
Online Now [139]:
Visitors: 138
Today: 8584
Total: 113457012
Forums › The Car › 206 Talk › Vibratechnics Rear Bush
tyrone81
PostPosted: Fri Mar 18, 2011 7:58 am Up
Any of you guys fitted one of these
www.awesome-gti.co.uk/...Prod=23179
I fitted on on my Focus ST, and loved it. For the ST it was £70, so cant grumble at this for £25.
It made gear changes smoother, when accelerating you didn't fell the engine moving, Felt sold. I liked the car slightly vibrating when ticking over, gave it a rally car feel.
Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
PostPosted: Fri Mar 18, 2011 8:04 am Up
A rally car feel? It's a similar price direct from VT.
tyrone81
PostPosted: Fri Mar 18, 2011 8:14 am Up
Don't you think? With the noise and vibration. Mabe different to the ST, The ST was a full mount, rather that just a bush..Didn't think you could buy direct. What you think about the mount?
PostPosted: Fri Mar 18, 2011 10:48 am Up
I've got all three fitted. The gearchange did feel a bit smoother but it takes a bit more than an engine mount to make it into a rally car but yes the refinement takes a nose dive. I needed mine because the Maniflow manifold is so long that a bit of movement in the engine was multiplied at the manifold.
I always buy direct from manufacturers where possible.
