Latest: Andyblue64
Overall: 17123
Online Now [489]:
Visitors: 488
Today: 137972
Total: 98506654
Forums › The Car › 206 Problems › Headlight problem
Headlight problem
Aar_Im_A_Pirate
PostPosted: Fri Mar 18, 2011 10:19 am Up
Got the angels put in, only problem is that they dip in the way instead of out the way (international lights.)
Is there anyway of fixing this??
Team: Derv
sillyhilly
PostPosted: Fri Mar 18, 2011 10:22 am Up
mod it.
Your profile picture and name greatly irritates me.
Hi Mikey Smile
MrrNoName
PostPosted: Fri Mar 18, 2011 10:27 am Up
what does that mean?
Ste
PostPosted: Fri Mar 18, 2011 10:28 am Up
Staff - Ste
Why did you fit them if you knew they were wrong? Confused
You'll probably need beam converters ect to get them to work and be legal.. It'd of been easier and better to get the correct ones tbf
The Cars:
Bailey
PostPosted: Fri Mar 18, 2011 10:29 am Up
sillyhilly wrote:
mod it.
Then dont look at them! Rolling Eyes
Antknee
Could always move to another country Razz
Aar_Im_A_Pirate
PostPosted: Fri Mar 18, 2011 10:35 am Up
sillyhilly. You are not ron burgundy.
But you most likely own a horse
Team: Derv
Aar_Im_A_Pirate
PostPosted: Fri Mar 18, 2011 10:36 am Up
They were a christmas present from the gf. Also you can only tell when getting the headlights aligned.
Meh, I have the crytals to put on for mot. Quick job changes it
Team: Derv
PostPosted: Fri Mar 18, 2011 10:37 am Up
blind other road users if there pointing wrong way ?
PostPosted: Fri Mar 18, 2011 10:42 am Up
i put a set of LHD lights on mine once and got flash by people on the otherside of the motorway when i was even in the slow lane! I would get them off!
meady
PostPosted: Fri Mar 18, 2011 10:43 am Up
Trade Rating: +45
you could buy my masked crystals off me would work a treat Smile
TEAM - I HATE FACEBOOK Smile
Golfguy206
were they made for european use, or uk use but just need aligning??
If they are for european use, I would send them back and get them swapped for uk use.
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
sillyhilly
PostPosted: Fri Mar 18, 2011 10:48 am Up
Don't need a horse thank you good sir, I get a good enough ride off of Mrs Aar_Im_A_Gimp.
Hi Mikey Smile
Aar_Im_A_Pirate
PostPosted: Fri Mar 18, 2011 11:04 am Up
Easy tiger. I came here to solve a problem and not have fisty cuffs. If you do not like it then I recommend that you grease your ass and slide on.
Edit: sorted now, was a switch at the bottom of the lights
Team: Derv
