Posted: Sat Mar 19, 2011 2:48 pm |
hi all im new on here so be gental ive noticed the temp gauge only goes 1/4 of the way up the dial, is this normal? thought it should go to 1/2 way when at normal temp, do you think the thermostat will need changing? if so is there a how to, cheers colin
Posted: Sat Mar 19, 2011 2:50 pm |
Not sure about the 2L but tis normal on the 1.4
Posted: Sat Mar 19, 2011 2:52 pm |
which temperature gauge? there is 2, one is coolant one is oil
Posted: Sat Mar 19, 2011 3:43 pm |
Seabook wrote: |
which temperature gauge? there is 2, one is coolant one is oil |
its the 05 so its only got the one !!!!!!!!! i think
Posted: Sat Mar 19, 2011 3:48 pm |
mines a 2l hdi diesel 2001 (y plate)
only has coolant temp and this rarely go's above 70 , usually after a good run about 75.
Posted: Sun Mar 20, 2011 4:05 pm |
perry081064 wrote: |
only has coolant temp and this rarely go's above 70 , usually after a good run about 75. |
should be ok then it's just when i had my bmw td i was told if the temp didnt reach half way on the gauge within 5 mins of driving the stat was failing and mpg would be pore
Posted: Sun Mar 20, 2011 4:32 pm |
Mine has oil & engine and it's an 02, the oil barely goes above 80 and the engine temp sits around 90
Posted: Sun Mar 20, 2011 4:38 pm |
my 03 sits around 75-80
not got oil temp
Posted: Sun Mar 20, 2011 5:19 pm |
mines 01/Y and i have the 2 gauges
waters normaly around 70 and oil is below the 90 mark
Posted: Mon Mar 21, 2011 2:49 am |
Generally, normal operating temp should be a minimum of 80 and maximum of 90...........less than 80 means a new thermostat is needed.
My 1.4hdi normally sits at just above 80 and just below 90 if i'm pushing it hard up a hill.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
