Posted: Mon Mar 21, 2011 8:54 am |
how do i remove them ?
Cant find anywhere an how to do it :s
Posted: Mon Mar 21, 2011 8:57 am |
there's a plastic bit that you pull to adjust the seatbelt height. Pull that off, it may be stiff but will come off.
Think it's a torx 10 or 15 bit you need to undo the lower cap of over where the seatbelt is attached. Undo that which will expose a bolt.
Undo that and the seatbelt will fall out.
Then prise the pillar off at the top and pull off.
Hope that helps
Posted: Mon Mar 21, 2011 8:58 am |
cheers will try that.
didnt want to pull it to hard in case i would break it lol
Posted: Mon Mar 21, 2011 10:05 am |
on my first 206 it was a pain and left all sticky crap. I proffered it with.
Posted: Mon Mar 21, 2011 10:08 am |
tiago90 wrote: |
didnt want to pull it to hard in case i would break it lol |
Make sure you pull the adjuster thingy evenly. I didn't, it snapped in half. Although not an issue, it just looks untidy.
