Forums › The Car › 206 Talk › Gearbox |
Posted: Tue Mar 22, 2011 7:12 am |
Is there any difference between rnr and rfn Gearboxes or are they the same for a GTi.
How do you tell which one fits each engine.
Posted: Tue Mar 22, 2011 8:11 am |
One is cable, the other is hydraulic?
Posted: Tue Mar 22, 2011 1:27 pm |
Both are the same. RFR is just older.
Engine wise RFN means 2 x lambda sensors. Nothing to do with the gearbox.
Posted: Wed Mar 23, 2011 5:23 am |
Thank you for that could not find an answer anywhere. i will upload pics once new gearbox fitted and the car is fully cleaned.
