Online Now [1180]:
Visitors: 1179
Today: 202229
Total: 151329392
Forums › The Car › 206 Talk › Engine strip down and rebuild
Forum Index › 206 Talk
Kersh
PostPosted: Fri Mar 25, 2011 5:00 am Up
hii!
right, basically i already know how engines operate and all that malarky but ive never actually done it or seen it for myself so i want to learn a bit more about engines and what exactly the internals of one look like etc etc. so my plan:
buy an engine stand, found 'healeys' ones on ebay for 50 quid ish
get a 2nd hand GTi engine from somehwere of a similar mileage to my own.
completely strip it down and rebuild it on the engine stand, maybe a couple of times, just to teach myself really, obviously re-doing all the gaskets/valves and cleaning it out/reconditioning it as i go.
i have a mechanic friend that will lend a hand along the way.
then eventually when im happy ive learnt all i can and its rebuilt properly switch it with my own (which has seen better days).
my question is, for a straight swap, same engine code (same year, same plex etc etc i dont need the ecu, bsi, key etc etc do i? and does it need programming of the ecu or anything like that?
i understand that this is a learning experience, the chances are ill rebuild it and itll run rough, rich or not at all. but i have access to an engine crane, very skilled mechanical help from a friend, a unit to do all the work in and time! and as GTis arnt worth s**t anymore i may as well use this car to learn what i want to learn Smile
good idea or bad?
Member number: 36
Seb
PostPosted: Fri Mar 25, 2011 5:04 am Up
Staff - Seb
No, the engine is completely seperate to the electronics and despite the common misconception that you do need to pair them, it's quited hard to pair circuitry to a lump of iron/aluminium Razz
The main thing you need to know is the right torque you need to apply to each bolt/nut when doing them back up. And obviously if you remove the pistons to make sure you put them back in the right cylinders.
PostPosted: Fri Mar 25, 2011 5:05 am Up
ECU etc will not matter as long as its a preplex engine you reuild.
Kersh
PostPosted: Fri Mar 25, 2011 5:07 am Up
yeaah i thought as much! yep dont worry it will be done so anally its untrue, following various internet guides and with his help i think it will be quite fun!
Member number: 36
PostPosted: Fri Mar 25, 2011 5:14 am Up
This sounds like a good project. Good luck with it, and take pics of your progress.
Kersh
PostPosted: Fri Mar 25, 2011 5:33 am Up
yeah will do! got my eye on a few little tuning upgrades as well i may include in the build, nothing major Smile
Member number: 36
Rob2859
PostPosted: Fri Mar 25, 2011 5:49 am Up
the main thing to make sure is you put the cylinders back in the right way up :D.
On a serious note though make a progress thread. You can get advice then as you go along. It could even be converted into a how-to when you are finished Very Happy
Kersh
PostPosted: Fri Mar 25, 2011 5:50 am Up
yeah i will do lol!
need to find an engine/car now to disect Smile
anyone know of anything?
Member number: 36
PostPosted: Fri Mar 25, 2011 5:53 am Up
Re-bore, polished ports, tuned cams. there's a fair bit you could do, but all comes at a cost and I don't know how the ECU would cope with it. It was far easier to play about with carbed engines.
PostPosted: Fri Mar 25, 2011 5:56 am Up
I have a preplex GTi engine you can have cheap Kersh.
Minor head gasket failure as far as I can tell.
Kersh
PostPosted: Fri Mar 25, 2011 5:57 am Up
yeah im more bothered about just learning about the thing really. but well see what happens!
Member number: 36
Bailey
PostPosted: Fri Mar 25, 2011 6:14 am Up
Good luck mate I would do the same as this if I had the space and time. A really good project and I'm sure there's s**t loads of information on here and the Internet on how to rebuild an engine, and what little modifications you can do,
Kersh
PostPosted: Fri Mar 25, 2011 6:18 am Up
cheers mate! yeah it should be alright, be nice thing to learn about anyway, and the best way to learn for sure!
Member number: 36
Kersh
PostPosted: Fri Mar 25, 2011 6:19 am Up
you have a PM!
Member number: 36
PostPosted: Fri Mar 25, 2011 7:16 am Up
Just buy the crappest worn out engine for as little cost as possible, strip it and learn from that. No point rebuilding a decent engine and if you intend on ending up with something decent, leave it to the professionals. There are so many things to measure accurately to make a good engine.
