Posted: Fri Mar 25, 2011 4:58 pm |
when i indicate to got right my indicator works fine but after my steering wheel locks to its normal position the indicator is still indication to go right??? do i need a new bulb???? HELP
Posted: Fri Mar 25, 2011 5:02 pm |
If I understand your post, it sounds like a problem with the self cancelling mechanism in the steering wheel.
Posted: Fri Mar 25, 2011 5:08 pm |
Trade Rating: +32
New stalk I think.
About £20.
Message Lee I'm sure he is selling a few.
E5GDM wrote: |
If I understand your post, it sounds like a problem with the self cancelling mechanism in the steering wheel. |
is it easy to sort?
Posted: Fri Mar 25, 2011 5:56 pm |
either a problem with the comms/ stalk unit or the rotating switch behind the steering wheel.
Posted: Sat Mar 26, 2011 3:21 am |
You'll have to take the steering wheel off to get to the self cancelling mechanism & the steering column cowling to change the indicator stalk. Shouldn't be that hard.
Posted: Sat Mar 26, 2011 5:11 am |
i've got that problem but mine decides to indicate left after its cancelled goin right just have to flick it back to where it should be and its fine
Posted: Sat Mar 26, 2011 6:42 am |
E5GDM wrote: |
You'll have to take the steering wheel off to get to the self cancelling mechanism & the steering column cowling to change the indicator stalk. Shouldn't be that hard. |
Lee has a guide on his fs bit takes 2 mins
