Latest: Worthy967
Overall: 17143
Online Now [560]:
Visitors: 559
Today: 42049
Total: 114165781
Forums › The Car › 206 Problems › drive shafted!
drive shafted!
jamie_206
PostPosted: Sat Mar 26, 2011 1:25 pm Up
Hi
I was changing my driverside shocks for coilovers yesterday . When refitting the coily the driveshaft popped out and now it wont go in . It dosent seem to line up with the grooves in the bearing . Should it just be as easy as lining the splines on the shaft with the splines in the bearing ? Then re fitting a new gaitor.
cheers
jamie_206
PostPosted: Sun Mar 27, 2011 5:13 am Up
Anyone?
macj
PostPosted: Sun Mar 27, 2011 5:34 am Up
Did the gaiter pop off as well.... put a little lube on the spline, it should go in easily
jamie_206
PostPosted: Sun Mar 27, 2011 11:24 am Up
No the gaitor ripped . So ive replaced that . I bunjie corded the hub up to stabalize it fitted a new ring clip to the shaft end and popped it in no problem.
