Latest: sparrowdclxvi
Overall: 17139
Online Now [251]:
Visitors: 250
Today: 2516
Total: 112576014
Forums › The Car › 206 Problems › air con
air con
206racer
PostPosted: Sun Mar 27, 2011 9:48 am Up
doing a few repairs to g/f car.When you turn on the air con should the radiator fan spin.You can hear the air con kick in and the revs increase but the fan doesnt spin?
hello
PostPosted: Sun Mar 27, 2011 10:02 am Up
the fan should be on as well, check the fan fuse/ wire
206racer
PostPosted: Sun Mar 27, 2011 10:13 am Up
The air con is working but not the fan.So wasnt sure if the fan needs to work.
The car is only a 51 reg 1.1.Do you know what fuse to look for and is it under dash or bonnet?
hello
PostPosted: Sun Mar 27, 2011 10:17 am Up
Why would turning the a/c on cause the radiator fan to come on? Surly it would only operate when the engine coolant reached the temp required to trigger it.
SDK206
PostPosted: Sun Mar 27, 2011 10:28 am Up
there should be two fans although ive never noticed on a pug, usually one for the engine the other to assist when the air con is working
If in doubt, drop a cog and put your foot down Smile
206racer
PostPosted: Sun Mar 27, 2011 10:32 am Up
I only have 1 fan at the front behind the grill then the radiator and then the air con radiator
hello
