Online Now [67]:
Visitors: 66
Today: 46919
Total: 117403720
Forums › The Car › 206 Problems › Rear Washer Jet
Rear Washer Jet
Username
PostPosted: Mon Mar 28, 2011 10:15 am Up
Hi There, my problem is this:
My rear washer jet is leaking & not reaching the rear windscreen.
When I turn the stalk for the water, it is comming / dripping out just in front of the drivers side rear wheel & making a wet patch on the road. Also there is one or two droplets in the rear comming from just above the rear seat belt on the drivers side.
I am assuming that the pipe / hose is broke, corroded or come apart. Has anyone had an issue like this & solve it? Would I have to take the rear door card off to get to the problem?
Thanks for your help.
206 GTi With Full SP Pack.
iainlovatt
PostPosted: Mon Mar 28, 2011 10:36 am Up
unsure on the fix but i would of thought that the water in the pipe expanded during the harsh winter and so and split the pipe! i think the pipe is all one piece too! Crying or Very sad
(My Garage)
Username
PostPosted: Mon Mar 28, 2011 10:46 am Up
Just took the 3rd brake light off to get to the pipe & gave it a little tug to see if it was still in one piece. there's a lot of tension there so I assume its still in one piece. Unless it connects to something near the gaiter at the top of the boot.
Cheers for the input all suggestions are welcome.
PostPosted: Mon Mar 28, 2011 11:35 am Up
Hope this helps. clips all over the place
Username
PostPosted: Mon Mar 28, 2011 12:11 pm Up
Cheers Macc1411, thats superb mate.
Will buy a new /used hose & now I have a project for the weekend Shocked
