Latest: Kifi69
Overall: 17183
Online Now [364]:
Visitors: 363
Today: 121525
Total: 143539153
Forums › The Car › Request a how-to › how to wire a turbo timer on a 138 gti so the a\c works
Forum IndexRequest a how-to
MALLE
PostPosted: Fri Mar 25, 2011 11:40 am Reply with quote Up
hi jus got a apexi timer would love a how to to get it hooked up rigth so the a\c works whn the timer is timing.
want to turbo charge
PostPosted: Fri Mar 25, 2011 11:53 am Reply with quote Up
Turbo timer on a NA engine?
nakednakeddave
PostPosted: Fri Mar 25, 2011 12:02 pm Reply with quote Up
erm what....?
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
ExoVyper
PostPosted: Fri Mar 25, 2011 12:13 pm Reply with quote Up
you do realise you cant lock the doors with it running?
i've got one and because of that its a tad useless unless im standing near the car
MALLE
PostPosted: Fri Mar 25, 2011 12:26 pm Reply with quote Up
Well I have mine wired it works fine but the a/c goes off when I take the key out and motor is running I lock the doors using the key not the remote so the car locks and is running on the timer just wanted to know if anyone has a wire setup that keeps the a/c on
ExoVyper
PostPosted: Fri Mar 25, 2011 12:35 pm Reply with quote Up
well it shouldn't go off... as the timer just simulates a key being in
have you tried turning the ac back on again? as the little power drop the turbo timer does might be whats knocking it off
Mattie-RS
PostPosted: Fri Mar 25, 2011 12:38 pm Reply with quote Up
bit silly on a NA
MALLE
PostPosted: Fri Mar 25, 2011 12:39 pm Reply with quote Up
Yeah I tried that the display come on but that is it now blower are anything
MALLE
PostPosted: Fri Mar 25, 2011 12:42 pm Reply with quote Up
Well I live in the tropic and when I run the car hard say on the track here if like to let the motor run for a 1min or so at idle just to level the temp
PostPosted: Fri Mar 25, 2011 1:20 pm Reply with quote Up
If your not in the car for the minute it's running, why do you need the a/c on?
MALLE
PostPosted: Fri Mar 25, 2011 1:43 pm Reply with quote Up
Over here is very hot so about 15 mins befor I leave work I go out turn the car on and let it run with the ac running to cool the car down inside but I have to stay with it so if the ac works with the timer I can leave it to run lock it and finsh work rhn go baqck to a cool car don't have a remote start so
PostPosted: Fri Mar 25, 2011 9:16 pm Reply with quote Up
15 mins idle on start up is never a good idea.....
  Quick Reply
Username:
Message:
Quote the last message
