Latest: Wan1977
Overall: 17118
Online Now [203]:
Visitors: 202
Today: 22690
Total: 95694802
Forums › The Car › 206 Problems › Tyre Pressure Problem
chilipepper
PostPosted: Tue Mar 29, 2011 1:05 pm Up
OK, so basically one of the reasons for my 206 failing its MOT was that there was a cut in the tyre (annoying as still lots of mileage in the tyre other than this) but it needed replacing to pass the MOT.
I have a set of alloys I was going to refurb, one of which has an almost brand new budget tyre on, perfect to fit for the MOT. I had let all the air out to make the refurb easier, so I popped it in the boot and took it to the local petrol station to fill it up with air, and it won't inflate it at all. Checked the air machine on the tyres on the car and its working fine.
I think basically it has too little air in it and the machine cant tell what the pressure is to then top it up, but I'm a bit stuck now as no way to fill it up with air, anyone got any ideas? (I work a lot so don't have time to take it to a garage before the retest on Thurs).
Moonstone GTi
Davels
PostPosted: Tue Mar 29, 2011 1:08 pm Up
Drive around and find a garage with a manual analogue gauge, however most if not all auto gauges I have seen on forecourt have a button with a picture of a flat tire which enables the setting to fill up a complete flat.
MrZiggerz
PostPosted: Tue Mar 29, 2011 1:09 pm Up
Press the "flat tyre" button.
chilipepper
PostPosted: Tue Mar 29, 2011 1:14 pm Up
I don't think it had a flat tyre button, but I'll check a couple of other garages nearby and see, thanks all!! Very Happy
Moonstone GTi
benashley
PostPosted: Tue Mar 29, 2011 1:18 pm Up
The tyre has Probably come off the bead, You will need to take it to a garage/tyre fitter to get them to blow it up for you. The compressors at service station wont inflate the tyre fast enough for the tyre to pop onto its bead.
chilipepper
PostPosted: Tue Mar 29, 2011 2:08 pm Up
Fixed! I'm such a tool I've never noticed the flat tyre button on those machines before lol! Sorted now anyway, thanks Smile
Moonstone GTi
PostPosted: Tue Mar 29, 2011 2:11 pm Up
i don't know that either Laughing
never use the air pump at the gas station Laughing
mdstone
PostPosted: Wed Mar 30, 2011 7:27 am Up
Regarding the MOT, if you didn't have a space saver and you were sure the tyre was ok, couldn't you have just swapped it for the spare in order to pass the MOT? You then just take the car in without a spare and then swap back over afterwards. I'm sure (unless its a myth) that they can't fail you for not having a spare but they can check the spare if it is still attached under the car.
Peugeot 206 GTi
PostPosted: Fri Apr 01, 2011 6:15 am Up
it is illegeal to use spare tyre for prolonged period.
have seen people taking 3 points for that
