Online Now [203]:
Visitors: 202
Today: 79064
Total: 127973142
Forums › The Car › Solved 206 Problems › 2.0 HDi MAF sensor
2.0 HDi MAF sensor
Chris10max
PostPosted: Fri Apr 08, 2011 12:55 pm Up
When I had my car mapped the mechanic said I had a broken MAF
I got a new one and on going to fit it found that the original wasn't plugged in.
I plugged it back in and my ODB2 reader isn't showing a MAF fault but I'm only getting 46MPG even on a long motorway run.
How can I tell if the MAF is broke and causing the high fuel consumption?
Is there anything else that can cause high fuel consumption?
206 2.0 HDI
PostPosted: Fri Apr 08, 2011 1:01 pm Up
don't think 46mpg is low
PostPosted: Fri Apr 08, 2011 1:02 pm Up
I get 39
Mattie-RS
PostPosted: Fri Apr 08, 2011 1:29 pm Up
46mpg is pretty good for the 2.0 HDi
Chris10max
I was hoping for 60MPG cruising at 80 on the motorway.
206 2.0 HDI
Mattie-RS
PostPosted: Fri Apr 08, 2011 1:43 pm Up
wishfull thinking im afraid
even i carnt get that in mine!!
you'll be lucky to get 50mpg
PostPosted: Fri Apr 08, 2011 1:45 pm Up
Iv had 60mpg and that was doing 60 on a long journey
PostPosted: Fri Apr 08, 2011 2:22 pm Up
if you want better mpg you better drive slower.....
like mikey said 60mph is quite good to mpg
Chris10max
PostPosted: Fri Apr 08, 2011 6:27 pm Up
On autotrader stats it says 70mpg was possible. Thought that was a bit ott but thought 60 was possible.
I drove a BMW 320d estate 300 miles towing 1.5 Ton of boat and got 40mpg on the way back without the boat it did 62mpg so thought a little car could do that easy.
206 2.0 HDI
-Dave-
PostPosted: Fri Apr 08, 2011 6:35 pm Up
Trade Rating: +36
Nevermind the fact that 70mph is the speed limit. 3 point's on your license is a lot to pay for a little extra MPG.
Ex 206 Owner.
Chris10max
PostPosted: Sat Apr 09, 2011 6:05 am Up
Sorry I ment 70. I would never speed on the motorway. I learnt my lesson when I got 3 points for doing 92 and been fined every year for 5 years by the insurance company.
206 2.0 HDI
PostPosted: Sat Apr 09, 2011 6:07 am Up
can't compare the mpg from a new diesel to an old diesel
technology advance!
