Latest: Andyblue64
Overall: 17123
Online Now [65]:
Visitors: 64
Today: 22160
Total: 98003306
Forums › The Car › 206 Problems › Drum to disk conversion
sicskate
PostPosted: Tue Apr 05, 2011 1:11 pm Up
Trade Rating: +13
Can the above be done?
I need a new axle for my gti, but I'm struggling to find one local and at a good price.
I would buy a recon, but I don't intend on keeping the car too much longer, otherwise I would.
I see the drum ones are common, and reasonable cost.
Cheers all.
307 1.4hdi Smile
PostPosted: Tue Apr 05, 2011 1:13 pm Up
easy, you just need to swap the trailing arm
sicskate
PostPosted: Tue Apr 05, 2011 1:27 pm Up
Trade Rating: +13
Don't you have the remove the arb and torsion bars to swap the trailing arms?
307 1.4hdi Smile
yes, you will have to remove both
l_jacka
PostPosted: Tue Apr 05, 2011 1:29 pm Up
So you are converting from disc to drum?
Looking to buy my first peugeot 206
PostPosted: Tue Apr 05, 2011 1:33 pm Up
Rolling Eyes
aparently he want to replace his damaged disc axle
by swap the trailing arm then he could potentially get the cheapest axle avalible in the market
sicskate
PostPosted: Tue Apr 05, 2011 1:35 pm Up
Trade Rating: +13
Correct.
Although I don't think it would be "easy".
307 1.4hdi Smile
PostPosted: Tue Apr 05, 2011 1:38 pm Up
sicskate wrote:
Correct.
not hard
even i don't go to the gym i still manage to bang off the torsion bars
sicskate
PostPosted: Tue Apr 05, 2011 1:51 pm Up
Trade Rating: +13
Will the trailing arms just slide out once the bars are out?
307 1.4hdi Smile
PostPosted: Tue Apr 05, 2011 2:18 pm Up
yes, a few tap from a hammer will knock the arms off
l_jacka
PostPosted: Tue Apr 05, 2011 2:23 pm Up
Whats actually damaged on the rear axle?
sicskate
PostPosted: Tue Apr 05, 2011 2:27 pm Up
Trade Rating: +13
It knocks quite abit. I'm guessing it's the bushes?
307 1.4hdi Smile
PostPosted: Tue Apr 05, 2011 2:28 pm Up
where knocks a bit?
the arm or the crossmembrane?
sicskate
PostPosted: Tue Apr 05, 2011 2:41 pm Up
Trade Rating: +13
Not too sure.
The wheel doesn't shake or wobble.
307 1.4hdi Smile
l_jacka
Any play in the arms? If there isn't then its not the bushes...
Check its not something stupid like exhaust hitting something or the spare wheel cage as that happens to quite often rattle
