Posted: Thu Apr 07, 2011 9:50 am |
Right my Air Con has decided not to work how nice of it.
Well when I push the button the little green light comes on but there is no click kind of noise coming from the engine like the it is engadging.
Anyone know what this could be ie Fuse, Relay or something more expensive.
Please help thanks
If I remember right it wont turn on if it's low on gas.
Posted: Thu Apr 07, 2011 9:51 am |
could be a fuse have you checked it?
on side note mine just sounds like there is a python in mine! lol
Posted: Thu Apr 07, 2011 9:53 am |
| CD-vRS wrote: |
| If I remember right it wont turn on if it's low on gas. |
It was serviced last year Chris, but saying that I havent really used it much.
Havent checked the fuse yet as Im not sure which one it is....
Posted: Thu Apr 07, 2011 9:56 am |
F15....15A......Instruments, multifunction screen, climate control, Nav control unit, radio.
Doubt it's a fuse.
Posted: Thu Apr 07, 2011 9:59 am |
| CD-vRS wrote: |
Doubt it's a fuse. |
If it was the fuse non of the above would be working and they are.
Posted: Thu Apr 07, 2011 10:08 am |
Could this simple be case of low gas? Or something more expensive?
Posted: Thu Apr 07, 2011 10:15 am |
are all the air-con pumps the same ?
if they are and yours is foobared ive got 2 spare ones from a 2.0 HDI i'll never put to use if you want one
Posted: Thu Apr 07, 2011 10:27 am |
mine has the exact same problem....took it to the garage and told me its gas....have an appointment next Tuesday for re-gas...and mine was gassed in September
Posted: Thu Apr 07, 2011 10:28 am |
| egouder wrote: |
mine has the exact same problem....took it to the garage and told me its gas....have an appointment next Tuesday for re-gas...and mine was gassed in September  |
That interesting let me know if it solves the problem mate
Posted: Thu Apr 07, 2011 10:30 am |
Does the fan come on when you press the button?
Posted: Thu Apr 07, 2011 10:31 am |
Nothing comes on just the green light Lee, I have manual Air Con as well so the fans work but the Air Con just doesnt kick in
Posted: Thu Apr 07, 2011 10:35 am |
Sounds like mine...as it does the exact same
Get this when I code read it
"Intermittent Fault - Air conditioning cut off circuit. Short circuit to earth or circuit open"
P1110
Coolant temp 3oC
Engine speed 0rpm
Actual delivery 50mm3/stroke
Air conditioning compressor cut-off Inactive
Main brake switch Inactive
Ignition positive Active
Maximum transitory flow 60mm3/stroke
Not followed it up tho, so dunno what the problem is
Posted: Thu Apr 07, 2011 10:38 am |
That fault wasnt there when you read them was it?
Posted: Thu Apr 07, 2011 10:39 am |
No it wasn't, I sent you every one that was there.
Problem does sound the exact same as mine tho, does sweet FA except the green light coming on
