Online Now [1382]:
Visitors: 1382
Today: 240653
Total: 152008382
Forums › The Car › Request a how-to › How do I disable lateral airbags?
Go to page 1, 2, 3  Next
carlosr23
PostPosted: Fri Apr 08, 2011 6:46 am Reply with quote Up
Hi, I bought my 206 with the lateral airbags (the ones attached to the side of each seat) exploded. The two front are OK.
I need to "bypass" them and not have the AIRBAG FAULT warning.
How can I do it?
I have heard something about a resistor and stuff like that
Carlos\r\nPeugeot 206 s16 2004
Will180
PostPosted: Fri Apr 08, 2011 7:00 am Reply with quote Up
id say crash, that should disable them
04/07/10. Black 206 XS 1.6 - Sold
29/03/11. Black GTI 180, Full Sp Kit
Aar_Im_A_Pirate
PostPosted: Fri Apr 08, 2011 7:22 am Reply with quote Up
What He Said
Team: Derv
carlosr23
If that was supossed to be a joke, look for another job my friend. Being a clown is not profitable this days if you´re not good
Ape
PostPosted: Fri Apr 08, 2011 7:35 am Reply with quote Up
Moved to the correct section.
Mattie-RS
PostPosted: Fri Apr 08, 2011 9:04 am Reply with quote Up
Would proberly need to find out the resistance of the airbag??
And put a resister across the terminal or summot i'd guess
ukskater01
PostPosted: Fri Apr 08, 2011 9:14 am Reply with quote Up
You will need to complete the circuit again, I'm afraid I don't know the resistance of the airbags though. Have you still got the old exploded airbags?
PostPosted: Fri Apr 08, 2011 10:34 am Reply with quote Up
Don't quote me on this but I think its a 47k resistor
Think you can turn them off in the ecu settings
PostPosted: Fri Apr 08, 2011 11:03 am Reply with quote Up
is that the same as the main airbag? (steering wheel one)
PostPosted: Fri Apr 08, 2011 11:07 am Reply with quote Up
2ohm resistor i think for the main one.
If your removing that, just take the whole airbag system out.
I'll have a look to see if you can just turn airbags off
PostPosted: Fri Apr 08, 2011 11:50 am Reply with quote Up
How can I do it?
Change the airbag ecu, part number is diferent between:
206 with just front airbags & pretensioner
206 with front side / curtain airbags & pretensioners.
PostPosted: Fri Apr 08, 2011 11:53 am Reply with quote Up
I'm not sure about this,but I remember seeing an option useing the PP2000 to activate/deactivate airbags,but that will shut the whole system down,not only the side ones Sad
PostPosted: Fri Apr 08, 2011 11:54 am Reply with quote Up
Thats why I said he needs to change to the basic airbag ecu Wink
PostPosted: Fri Apr 08, 2011 12:25 pm Reply with quote Up
What He Said
carlosr23
PostPosted: Fri Apr 08, 2011 12:47 pm Reply with quote Up
I looked under each seat and the conector to each airbag has three wires. I dont know wich two bring to put the resistor and try.
The exploded airbas stillare inside each seat
It would be good to know the resitor ohm and try it
Also have the peugept planet I did put ABSENT on each of the lateral airbags but it would not allowme, I think it gives me an error trying to comunicate via internet with some address
Page 1 of 3
  Quick Reply
Username:
Message:
Quote the last message
