Online Now [225]:
Visitors: 225
Today: 60280
Total: 142570706
Forums › The Car › 206 Talk › Muddy coolant.
Muddy coolant.
jonny_fulton03
PostPosted: Fri Apr 08, 2011 8:05 am Up
hey guys,
Ive just used a syringe to take some coolant from expansion tank and its a muddy brown colour. Dont know when it was last changed! Does coolant normally go this colour when its reached its sell by date? lol i mixed some of it in a glass of water to see if there was any oil in it and it looked like most of it was sediment as it started to sink to the bottom! nothing floated on top! just wondered if this is what usually happens? Cheers Joni
Ape
PostPosted: Fri Apr 08, 2011 8:13 am Up
Be worth a flush through and change. Is there much coolant in the mix? sounds like a lot of rust in the water.
MrZiggerz
PostPosted: Fri Apr 08, 2011 9:10 am Up
Either that or you mixed coolants.
jonny_fulton03
PostPosted: Fri Apr 08, 2011 9:41 am Up
i heard somewhere that this can happen if you add tap water to the mixture. any truth in this?
PostPosted: Fri Apr 08, 2011 10:34 am Up
I don't think that happen cuz of adding tap water to the mixture,but it would be much better to use disteled water with the mixture.
But since your coolant is muddy and brown color,then as they said,it must be mixed,with green ones,or blue one,because I think that Peugeot use the red one,anyway,change it and see what happen,not a problem since you don't have oil.
Tim
PostPosted: Fri Apr 08, 2011 11:03 am Up
rust?
PostPosted: Fri Apr 08, 2011 11:10 am Up
If you use just water it will corrode the system because proper antifreeze coolant has rust inhibitors which protect it.
Just flush it out and change the coolant Smile
