Latest: Kifi69
Overall: 17183
Online Now [358]:
Visitors: 358
Today: 54325
Total: 144072215
Forums › The Car › 206 Talk › replace steering rack
G-10
PostPosted: Fri Apr 08, 2011 5:24 am Up
My steering rack needs changing. I want to tackle the task my self, seems quite easy. Just for reference is there a DIY on the forum
My car is a 2003 1.1
Also will a rack from a 2001 1.1 fit?
Mr_Cellexe
PostPosted: Fri Apr 08, 2011 5:41 am Up
think they were all the same.
not a simple job tho.
MrZiggerz
PostPosted: Fri Apr 08, 2011 5:44 am Up
You wish it was a simple job to change a rack Wink
G-10
PostPosted: Fri Apr 08, 2011 6:31 am Up
Whats so hard about it?
As far as i know undo the two end bolts. Another two in the middle (not sure if access is easy) Undo the pipe for the fluid.
I have access to a pit
PostPosted: Fri Apr 08, 2011 6:32 am Up
The steering rack is attached to the subframe so that needs removing...
G-10
PostPosted: Fri Apr 08, 2011 6:34 am Up
Can the two bolts that attach to the sub frame not be removed without removing the subframe from under the car?
G-10
PostPosted: Fri Apr 08, 2011 6:40 am Up
These two attach to the subframe
bellevuespares
PostPosted: Fri Apr 08, 2011 10:05 am Up
You may want to start it, but i assure you, you wil not complete it unless you know what you are doing and the order to do it in. Its a big job mate.
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
