Posted: Fri Apr 08, 2011 5:24 am |
My steering rack needs changing. I want to tackle the task my self, seems quite easy. Just for reference is there a DIY on the forum
My car is a 2003 1.1
Also will a rack from a 2001 1.1 fit?
Posted: Fri Apr 08, 2011 5:41 am |
think they were all the same.
not a simple job tho.
Posted: Fri Apr 08, 2011 5:44 am |
You wish it was a simple job to change a rack
Posted: Fri Apr 08, 2011 6:31 am |
Whats so hard about it?
As far as i know undo the two end bolts. Another two in the middle (not sure if access is easy) Undo the pipe for the fluid.
I have access to a pit
Posted: Fri Apr 08, 2011 6:32 am |
The steering rack is attached to the subframe so that needs removing...
Posted: Fri Apr 08, 2011 6:34 am |
Can the two bolts that attach to the sub frame not be removed without removing the subframe from under the car?
Posted: Fri Apr 08, 2011 6:40 am |
These two attach to the subframe
Posted: Fri Apr 08, 2011 10:05 am |
You may want to start it, but i assure you, you wil not complete it unless you know what you are doing and the order to do it in. Its a big job mate.
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
