Online Now [859]:
Visitors: 858
Today: 197809
Total: 150032849
Forums › The Car › Request a how-to › How to req.: replace exterior door handles
davieboy86
PostPosted: Mon Feb 14, 2011 8:14 am Reply with quote Up
Hey guys, I've just colour coded my bump strips and now my door handles now look so far out of place it's ridiculous.
I've managed to pick up one colour coded handle and I'm going to respray the other side but I have no idea how to remove them/ install new ones.
Any sort of help or picture guide would be really really appreciated.
Thanks all.
Antknee
PostPosted: Mon Feb 14, 2011 8:20 am Reply with quote Up
Think it's riveted on, not done it myself but i think you have to take the door card off and drill out the rivets, then rivet the new one back on
-RAJ-
PostPosted: Mon Feb 14, 2011 8:43 am Reply with quote Up
yh as said above, lift the door handle up and drill the two rivets out, then re-rivet back on. tbh if you can get the car in a garage some ppl have just sprayed them while on the car
davieboy86
PostPosted: Mon Feb 14, 2011 11:14 am Reply with quote Up
Well, I had a feeling I'd read it was riveted on, I have absolutely no experience riveting so im a bit stuck there.
I would try doing it on the car but I've only got a normal, car sized garage not one with any type of working area, I struggle to get out the car when I've parked in there lol.
Hmm, not sure of my next move... ...
hobnob48
PostPosted: Mon Feb 14, 2011 11:53 am Reply with quote Up
Gazeebo? Go buy one of those cheapo gazzebos with the sides and make you own spray shop inside it?
Mate of mine did it with scaffolding and tarpooling. Just make sure you make it wind tight and you have a perfect workshop that you can take down when not needed
NathanG
PostPosted: Mon Feb 14, 2011 12:36 pm Reply with quote Up
I changed mine about a year ago. Take off the door card, peel back the liner, unclip the handle, drill out the rivets with a small drill bill (like 2mm), pull out the handle. Putting a new one on is the reverse. Just buy a cheap riveter from ebay with rivets. Simples.
davieboy86
PostPosted: Mon Feb 14, 2011 12:46 pm Reply with quote Up
thanks guys. I would love to have a mini spray shop in the garden but i've already sprayed most of my bigger parts on the car, and also the garage isnt next to the house with a driveway its just round the corner from the house, leaving up a gazebo round the car is asking for the pikeys to come and explore lol.
Well that doesnt sound too tricky to rivet, may well have to have a go myself when i can get hold of another exterior handle.
Rob2859
PostPosted: Mon Feb 14, 2011 1:13 pm Reply with quote Up
Would it not pe possible to drill the rivets out then just screw self tappers in?
PostPosted: Mon Feb 14, 2011 1:14 pm Reply with quote Up
And have some scrotum simply unscrew them to gain entry to your car?
NathanG
PostPosted: Mon Feb 14, 2011 1:54 pm Reply with quote Up
Just get something like this Clicky. Try a couple of rivets out 1st on a piece of wood or spare metal so you know the size to use before you drill them out.
Follow this to remove your door cards. You'll need to have the window up though to get to the back of the handle.
The entire job, including taking off the door trim takes like 10 mins per side, if that.
Rob2859
PostPosted: Mon Feb 14, 2011 2:01 pm Reply with quote Up
Fair point. although not sure that would work it would just stop you getting in at all
EmoStu
PostPosted: Tue Apr 12, 2011 6:38 am Reply with quote Up
Does anyone know what size rivets are used on the door handles? M3, M4, M5, M6? Very Happy
EmoStu
Peugeot 206 1.6 XSi Firedance
Rob2859
PostPosted: Tue Apr 12, 2011 6:56 am Reply with quote Up
Done mine but no idea what size they were sorry Very Happy
  Quick Reply
Username:
Message:
Quote the last message
