Latest: Flyin180
Overall: 17116
Online Now [70]:
Visitors: 69
Today: 11629
Total: 95029731
Forums › The Car › 206 Talk › Bolt Length
Bolt Length
vanman_foci
PostPosted: Sat Apr 16, 2011 3:19 am Up
Morning all
Running a set of 17" Monza R's
15mm spacers on the front and 20mm on the rear.
Looking for extended lockers but not sure what size the original bolt is, what size bolt I need now, and does it matter that the front bolt will sit 5mm more into the hub?
Cheers
Uz
PostPosted: Sat Apr 16, 2011 3:25 am Up
Standard after bolt lengths are 25mm going by my wheels bolts so watch 40mm at the front and 55mm at the back.
Does the car have hubs or discs at the back..?
vanman_foci
PostPosted: Sat Apr 16, 2011 3:26 am Up
hubs
they only do sets of 4 on ebay so was wondering if i could get way with the same length for front and back
Uz
PostPosted: Sat Apr 16, 2011 3:28 am Up
You may be able to get away with the longer out of the two bolts at the front because the bolts don't actually touch anything against the back of the front hubs.
vanman_foci
PostPosted: Sat Apr 16, 2011 3:33 am Up
so what size do i need?
PostPosted: Sat Apr 16, 2011 6:41 am Up
Standard are
12X1.25-38
M12 bolts, with threads every 1.25mm, and thread length of 38mm
So front need to be 12x1.25-53
Rear need to be 12x1.25-58
vanman_foci
PostPosted: Sat Apr 16, 2011 4:04 pm Up
Lee wrote:
Standard are
12X1.25-38
would 58mm be ok for the front lee?
vanman_foci
PostPosted: Sun Apr 17, 2011 3:05 am Up
I gather these are no good?
cgi.ebay.co.uk/Locking...574wt_1139
vanman_foci
PostPosted: Sun Apr 17, 2011 3:06 am Up
Or I have found these
cgi.ebay.co.uk/16-X-EX...3143wt_905
PostPosted: Sun Apr 17, 2011 8:12 am Up
one is taper one is flat seat Laughing
which one do you need?
