Latest: flipflap
Overall: 17140
Online Now [122]:
Visitors: 121
Today: 5951
Total: 113753757
Forums › The Car › 206 Problems › my rear wheels bang?
whitey4lyf
PostPosted: Sun Apr 10, 2011 2:10 am Up
i recently changed my dampers as my back wheels was bangin but this did not spolve the problem even tho one was sieced i then got told that my rear drivers wheel is wobberling anyone know the problem?
D. M. White
PostPosted: Sun Apr 10, 2011 2:23 am Up
If wheel is wobbling could be bearing jack up car and wiggle wheel see if there is any play
brad-morris
PostPosted: Sun Apr 10, 2011 6:33 am Up
are they aftermarket wheels? if so what bolts have you used on them?
whitey4lyf
PostPosted: Mon Apr 11, 2011 5:51 am Up
nah they standard alloys mate gna av a nosey at work today!
D. M. White
bellevuespares
PostPosted: Mon Apr 11, 2011 6:08 am Up
If the wheel doesnt have play in when you rock it when jacked up then double check your wheels nuts, if there ok then id start to look around the rear axle, As we all know its a common fault of pugs. A knock from the axle could well sound like a knock from the rear wheel.
bellevuespares.com
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
