Latest: heikkisj
Overall: 17126
Online Now [296]:
Visitors: 295
Today: 2078
Total: 100374848
Forums › The Car › 206 Problems › Roof - Don't switch off.
Bagsy
PostPosted: Sun Apr 10, 2011 12:36 pm Up
We recently bought a 2003 206cc. Unfortunately just at the start of closing the roof the ignition was switched off.
The roof will now not close (I will have to do it manually).
Will this reset the electonic action, or do I need to do something else?
Bagsy
PostPosted: Sun Apr 10, 2011 12:42 pm Up
You can try & close it fully manually to see if it resets, gotta be worth a try.
Instructions are in the handbook as you need to release the emergency valve on the hydraulic system in the boot to allow manual operation.
PostPosted: Sun Apr 10, 2011 12:43 pm Up
try to take the battery off,but do it in the right way "Safe Reboot",and that may fix your problem,if not,then have it checked by diagnostic pc.
Bagsy
PostPosted: Mon Apr 11, 2011 4:24 am Up
Thank you both for your suggestions.
After an emergency close, the roof now works, although a bit clunky. However, I am hopefully that it just needs the hydraulic pressure increase.
I noted that the manual does not say to tighten the hydraulic pressure release nut. Does the system need recharging from a garage or will it recharge after a short run?
PostPosted: Mon Apr 11, 2011 4:25 am Up
You did shut the emergency valve again after closing the roof manually?
Bagsy
PostPosted: Mon Apr 11, 2011 5:01 am Up
Yes. But I am not sure why the manual does not inform you to. Someone may forget.
PostPosted: Mon Apr 11, 2011 5:55 am Up
The later owners manuals are different Wink
Bagsy
PostPosted: Mon Apr 11, 2011 7:12 am Up
Thanks.
