Latest: sparrowdclxvi
Overall: 17139
Online Now [122]:
Visitors: 121
Today: 17368
Total: 112492769
Forums › The Car › 206 Problems › MOT failure
MOT failure
Diablo
PostPosted: Mon Apr 11, 2011 10:25 am Up
Ok so went to do my MOT today thinking it would pass but failed on 10 seperate points!! Sad
1. Offside registration plate lamp not working
2. Offside headlamp aim too high
3. Offside front constant velocity joint gaiter insecurely mounted to its housing
4. Nearside balljoint
5. Offside balljoint
6. Nearside rear shock absorber has an excessively worn rubber bush
7. Rear brake load sensing valve linkage seized
8. Front (pipe) exhaust has a major leak of exhaust gases
9. Exhaust emmissions carbon monoxide content after 2nd fast idle excessive
10. Exhaust emmissions lambda reading after 2nd fast idle outside specified limits
Most of it seems quite simple to do but can anyone tell me whats involved and how much the constant velocity gaiter, the rubber bush on the shock and the rear brake valve are likely to cost to fix?
W reg 1.4 lx in diablo red. lowered and with 17 inch konig alloys
PostPosted: Mon Apr 11, 2011 10:27 am Up
CV Gaiter means removal of Driveshaft IIRC.
New Shock.
and lots of WD40 on brake valve.
Diablo
PostPosted: Mon Apr 11, 2011 10:31 am Up
New Shock.
No way to fix the old shock? Its not a standard one otherwise I wouldn't bother fixing would just buy a new one
PostPosted: Mon Apr 11, 2011 10:32 am Up
I am sure the rubber bush is part of the shock...
Diablo
PostPosted: Mon Apr 11, 2011 10:36 am Up
Doesn't sound good then. But thanks for your help
Still_Rolling
PostPosted: Mon Apr 11, 2011 10:46 am Up
How long's the rear shocks been on? Rear shock bush is quite common, can be caused by fitting issues, i.e. when the mechanic was fitting them, he tightened up the bolts all the way before putting he car on the floor. It causes the bush to rotate in its mounting, its a common issue on most cars with torsion bar suspension.
Always Rolling...
Andy180
PostPosted: Mon Apr 11, 2011 10:50 am Up
you could try and sent the shocker back to the company you got it from they should be able replace the worn bush i had the same problem on my avo rear shocker
GTI 180
Diablo
PostPosted: Mon Apr 11, 2011 11:03 am Up
its been on for about 2 and a half years now so its defo out of warrenty
PostPosted: Mon Apr 11, 2011 11:19 am Up
You can get a split CV boot kit which you glue along a tongue and groove seam. Saves taking the driveshaft out. I've used them before and never had a problem with them.
leigh_boy
PostPosted: Tue Apr 12, 2011 4:51 am Up
dito about £13 from car parts store
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Tue Apr 12, 2011 4:57 am Up
Just got similar on this today, except mine had fallen off. Was told it was a spring like thing on the rear brake, see if you can unseize it. If not I was told you won't be able to buy one brand new so you would have to buy the whole valve, very expensive.
SDK206
PostPosted: Tue Apr 12, 2011 7:48 am Up
its just insecure, probably the plastic ones just put a new securing strap round it or for simplicity a cable tie Smile
If in doubt, drop a cog and put your foot down Smile
