Latest: Worthy967
Overall: 17143
Online Now [580]:
Visitors: 579
Today: 90984
Total: 114388396
Forums › The Car › 206 Problems › car wont start!
car wont start!
sam-c
PostPosted: Sat Apr 16, 2011 2:56 am Up
Yorkshire Area Rep - SamC
Hi guys really need some help...
I set off realised my indicator bulb was out so came back as was only on the edge of the village and changed the bulb and now the car wont start
The electrics are fine and starter motor sounds like its starting but not making the engine tick over
im sure its not the battery
any help much appreciated
sam
PostPosted: Sat Apr 16, 2011 2:57 am Up
Blown fuse?
Sounds silly... But, you got fuel?
PostPosted: Sat Apr 16, 2011 2:59 am Up
I know im txting you at same time like but try disconnecting your batt mate and leave for 5 mins
sorry i couldnt come help you out
sam-c
ill have a look at fuses under the bonet but dont think so :/
yup its got fuel Very Happy
PostPosted: Sat Apr 16, 2011 3:03 am Up
Is the starter motor turning the engine over? Not clear in original post.
If it was a front bulb, check all the connections under the bonnet, possibly caught a connecting block
sam-c
PostPosted: Sat Apr 16, 2011 3:07 am Up
it was a rear light
and no it doesnt turn the engine over sorry
sam-c
PostPosted: Sat Apr 16, 2011 3:08 am Up
btw checked all fuses under the bonnet and there all fine
PostPosted: Sat Apr 16, 2011 3:14 am Up
Has your 206 got the big red fuel cut off button under the bonnet by the passenger side strut.
sam-c
PostPosted: Sat Apr 16, 2011 3:16 am Up
i cant see any big red buttons so im going to go with no :/
Mattie-RS
PostPosted: Sat Apr 16, 2011 3:21 am Up
Might be your immobiliser with you loosing ya key :/
sam-c
PostPosted: Sat Apr 16, 2011 3:23 am Up
i lost my key over a year ago mattie Razz its not imobiliser as i had a problem with that a few weeks ago and then the starter motor doesnt even spool up lol
PostPosted: Sat Apr 16, 2011 3:25 am Up
Is the starter spinning? If just clicking then could be battery or earth connection
If it is spinning, sounds like starter not engageing onto fly wheel. Give the starter a clout while someone turns the key
sam-c
PostPosted: Sat Apr 16, 2011 3:27 am Up
starter motor is spinning so sounds like that could be a problem :/ is this a permanent fix? lol
PostPosted: Sat Apr 16, 2011 3:30 am Up
If it starts with a knock then probably solenoid needed. They can work fine for weeks then miss once, then work fine again and never have another problem with it.
Just keep your wheel brace handy lol
sam-c
PostPosted: Sat Apr 16, 2011 3:32 am Up
well mechanics on his way out now so hopefully he can sort it without it having to be towed!
