Latest: SA01
Overall: 17138
Online Now [105]:
Visitors: 104
Today: 21225
Total: 112191184
Forums › The Car › 206 Problems › Brother locked out of his 206
PostPosted: Sun Apr 17, 2011 4:54 am Up
Due to my brothers xsi being off the road at the mo he has to start it now and again, anyway went down last week to start it and the battery is completely dead, the main problem is he cannot get into the car to jump start it because he has no door locks due to it being broken into a few years back, anybody recommend a way of gaining access to the car or popping the bonnet without causing any damage?
PostPosted: Sun Apr 17, 2011 5:00 am Up
Point and laugh? Not helpful in the slightest but it will take his mind of it as he gets angry at you.
Edit: I'll be slightly more helpful. Is it a 3 door or 5? Pre-lexed or Plexed? If its a 3 dor preplexed with no alarm then just break the rear glass and through the window? Will cost no more than £10/15 from a scrappy. (That is an extreme method) however feel it may be one of your only options.
EuroPeugeot
PostPosted: Sun Apr 17, 2011 5:10 am Up
As above really
PostPosted: Sun Apr 17, 2011 5:14 am Up
Its a 206, not exactly the hardest car to force entry in to without any damage.
I dont know why people bother removing the door locks as it doesnt make a 206 any more secure Rolling Eyes
it's a 3 door, not sure if it's plexed but know it's a Y reg
PostPosted: Sun Apr 17, 2011 5:15 am Up
Call the AA / RAC out, they will open it in seconds Wink
PostPosted: Sun Apr 17, 2011 5:20 am Up
thats what i've though too but just wanted to see if anyone here knew or had their own way
PostPosted: Sun Apr 17, 2011 5:22 am Up
Depends what tools you have access to Wink
With the proper lock out tools they are easy to open Laughing
Mr_Cellexe
PostPosted: Sun Apr 17, 2011 5:25 am Up
remove the base seal strip on the driver/passenger window. get a coat hanger and use it to trigger the handle mechanism (a piece of metal rod). et voila Wink (did this at usc back in 08 when i lost my key in the field! Sad
PostPosted: Sun Apr 17, 2011 5:27 am Up
what was you doing with a coat hanger at usc? Laughing Razz
PostPosted: Sun Apr 17, 2011 5:38 am Up
What He Said
Trim removal tool with a hook on also works, and they are generally slightly bigger and flat.
You can get your hand into to the wire to pop the bonnet too
Mr_Cellexe
PostPosted: Sun Apr 17, 2011 5:46 am Up
lol. didnt have a coat hanger but i did have an extra long tent peg Wink
longeatonlad
PostPosted: Mon Apr 18, 2011 1:44 am Up
brake cable in a loop, fish it in pul up the catch, job done lol
206 gti 180 Wink
rudebwoi93
PostPosted: Mon Apr 18, 2011 1:59 am Up
I was also going to suggest breaking s window 3 dr rear would be easier to refit I imagine lol
EDIT: Oh and as a preventative measure, you can buy this thing that charges the battery via solar power. I used to have one that plugged Ito the cigarette lighter, don't know if it worked or not but I vaguely remember it did. Im sure there are better devices out there now as this was like 10 years ago
PostPosted: Mon Apr 18, 2011 2:18 am Up
I got locked in mine other week Laughing deadlocks came on Confused (also had locks removed)
Once bonnets open run two wire from Batt (just little ones) tuck them Behind bumper, if it goes flat again can untuck the wires put a batt on them and will give you just enoth power for the locks to work and get bonnet open,
