Latest: ArtistKS
Overall: 17145
Online Now [52]:
Visitors: 51
Today: 17030
Total: 115957915
Forums › The Car › 206 Problems › gear change aint smooth..
bisphenol-a
PostPosted: Sat May 14, 2011 1:22 pm Up
what am i looking to change?
im not sure if its the gear box or whatever component i should be looking to change.
but moving up from low gears 1,2,3, its rather 'rocky'. its not stiff, doesnt make any grinding noise. just a audible deep gear changing sound but i think thats normal. its just difficult to change up the first 3 gears quickly and efficiently. not sure if its a psychological thing, but it improves quites a bit when the car is all warmed up. fresh start from cold is really irritating to use.
it just does not slide very nicely or smoothly as compared when i go from 3 to 4.
smoothest from 4-5.
would changing a gear box to a brand new one give me that smooth and maybe quieter gear change? or am i looking at the wrong part?
ukskater01
PostPosted: Sat May 14, 2011 1:35 pm Up
When was the gearbox oil changed last? Could be the problem, you would be best getting a garage to take a look
karimali831
PostPosted: Sat May 14, 2011 1:41 pm Up
I have the same issue but a new gear box would cost you around 500.
206 GTI 180
elcamino
PostPosted: Sat May 14, 2011 1:42 pm Up
If it is difficult to change gear when its cold i think u should change gearbox oil first.wrong type oil might be used before.its worth before u change a component.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Quarmbo
PostPosted: Sat May 14, 2011 1:45 pm Up
Plus, its a peugeot...
Ford SportGay-A
PostPosted: Sat May 14, 2011 1:48 pm Up
Common problem on 206s, unless it's really bad I wouldn't worry about it.
karimali831
PostPosted: Sat May 14, 2011 1:54 pm Up
figure this one out...
I can only change gear 1 smoothly when the car stops??
otherwise I have to force it with a bit of pressure.
also can this contribute to a rattling exhaust?
206 GTI 180
bisphenol-a
PostPosted: Sat May 14, 2011 2:18 pm Up
i was thinking it was changed the last servicing because it was worse before i brought it there then when i got it back it was better. but not the best.
that was in february.
Bill_G
PostPosted: Sat May 14, 2011 2:50 pm Up
i think peugeot boxes are all 'notchy', i know mine is
unique doesn't always mean useful
karimali831
PostPosted: Mon May 16, 2011 11:32 am Up
is it a normal occurence for the gear stick to be shaking while on gear 4 and 5?
206 GTI 180
MrZiggerz
PostPosted: Mon May 16, 2011 11:40 am Up
Maybe one of your engine mounts are on its way out.
