Online Now [33]:
Visitors: 32
Today: 20441
Total: 116707208
Forums › The Car › 206 Problems › Wont start!!!
Wont start!!!
wobblycat
PostPosted: Mon Apr 18, 2011 1:17 pm Up
After fiddling about with the bulbs, my drivers side dipped doesn't work now !?!? So I thought it would be a fuse, I removed a couple of 10A in the engine bay to check them and put them back, now everything on the car has reset and it won't start, the wiper blade turns once without any cause
yeah
PostPosted: Mon Apr 18, 2011 1:19 pm Up
Year of 206? ? ?
2 totally different electrical systems used & your just p**sing in to the wind until you give us more details
wobblycat
04
yeah
PostPosted: Mon Apr 18, 2011 1:22 pm Up
wobblycat wrote:
04
Oh dear its multiplexed & you have been pulling fuses out with the system powered up Laughing
Shut down the BSI unit, check the fuses in the BSI unit & the BM34 fuse box under the bonnet, reboot the BSI & cross your fingers you aint killed the BSI by p**sing around with the fuse box with the battery connected.
wobblycat
PostPosted: Mon Apr 18, 2011 1:27 pm Up
How do I shut down the bsi unit?
yeah
Search!
Edit: In future please use the search button, it is there for a reason!
www.206info.co.uk/Foru...eboot.html
PostPosted: Mon Apr 18, 2011 1:29 pm Up
Read and research...exactly the thing you should have done before messing about. Just hope luck is on your side or you might be emptying your savings account
wobblycat
PostPosted: Mon Apr 18, 2011 2:06 pm Up
Arhhh nah :/ I rebooted it and the same problem
yeah
PostPosted: Mon Apr 18, 2011 2:08 pm Up
Have you checked the other fuses to see if they have blown?
PostPosted: Mon Apr 18, 2011 2:09 pm Up
Also, you sure you have put them back in the correct places?
wobblycat
PostPosted: Mon Apr 18, 2011 2:10 pm Up
Which fuses would it be?
yeah
wobblycat
PostPosted: Mon Apr 18, 2011 2:12 pm Up
yeah
PostPosted: Mon Apr 18, 2011 2:14 pm Up
Check them ALL carefully.
Shut the BSI down & disconnect the battery first though!
BSI unit is the software driven computer brain of the car that controls ALL the elctrical systems over a digital CAN VAN multiplex network.
Pulling fuses out at random with the battery connected isnt recomended Wink
PostPosted: Mon Apr 18, 2011 2:16 pm Up
As above... however to check they are all in the correct place:
www.206info.co.uk/Foru...t=108.html
Does it not amaze you how I can find everything? Search.
PostPosted: Mon Apr 18, 2011 2:18 pm Up
Fuses need testing with a multimeter or tester to see if they have blown.
