Latest: Andyblue64
Overall: 17123
Online Now [190]:
Visitors: 189
Today: 32921
Total: 98062305
Forums › The Car › 206 Problems › 180 problems
180 problems
Go to page 1, 2, 3  Next
4ndy180
PostPosted: Mon Apr 18, 2011 3:01 pm Up
Just bought a 180 and have afew faults:
Rear disks badly pitted and h/brake not holding
Oil leak
Horn not working
Judder in 1st gear when setting off
Can anyone help, advise if these are common ?
180 judder is doin my nutt in, lol
PostPosted: Mon Apr 18, 2011 3:03 pm Up
paid money to fix it?
PostPosted: Mon Apr 18, 2011 3:05 pm Up
I reckon you should get them fixed. It's the only way to get them sorted.
Ali_H
PostPosted: Mon Apr 18, 2011 3:06 pm Up
Judder is fairly normal with 180's.
kurtis wrote:
PostPosted: Mon Apr 18, 2011 3:07 pm Up
won't happen on a perfectly fine flywheel Laughing
4ndy180
PostPosted: Mon Apr 18, 2011 3:17 pm Up
lol Rolling Eyes
SAB206
PostPosted: Mon Apr 18, 2011 3:31 pm Up
All sound fairly common to me.
www.sab-graphics.com
I AM SYDLEXIC!
Andy180
PostPosted: Mon Apr 18, 2011 3:46 pm Up
wheres the oil leak coming from? if its from the oil filter it could be the oil filter housing a common fault on 180's iirc, only one id pay to have fixed is the 1st gear judder as it sounds like this flywheel problem most 180s suffer with the rest of the jobs you could easily do yourself.
GTI 180
Icetto
PostPosted: Tue Apr 19, 2011 12:34 am Up
Is the judder only noticeable when your car is still cold?
Mine does that between 2000rpm and 3000rpm when the car is still cold. If it's warmed up then it drives smoothly.
Big_Rich180
PostPosted: Tue Apr 19, 2011 2:06 am Up
Oil leak
Horn not working
Take it back to the garage.....unless it was a private sale.
its not from Mansfield is it??
L18LTM
PostPosted: Tue Apr 19, 2011 3:23 am Up
Judder is common, warped flywheel ( i think )
Dream As If You'll Live Forever, Live As If You'll Die Today Smile
dalton-gti-180
PostPosted: Tue Apr 19, 2011 4:01 am Up
my horn didnt work once then i just held it on one night and it started coming back to life very slowly though haha like a drowning duck buck backwords Very Happy
your defeat now is your victory in the future
4ndy180
PostPosted: Tue Apr 19, 2011 5:34 am Up
Did notice that the horn is quite low, behind front valence, so could possibly got gunked up with road surface debris, will try to hold down also. Out of interest is the 12v dc fed direct from battery and the cct made on the 0v side by the steering wheel contact?
4ndy180
PostPosted: Tue Apr 19, 2011 5:39 am Up
Yes that's were I saw the oil dripping from when I had a look yesterday. Where best place to buy the housing if that is the case?
The main dealers seem to be praised hell of a lot on here whereas on all my other cars Nissan, SEAT, FIAT, Subaru and Toyota the dealers were useless. Time will tell I guess as the car may need to go in for the flywheel/clutch replacement
4ndy180
PostPosted: Tue Apr 19, 2011 5:40 am Up
Judder is all the time, not just when cold Sad
Page 1 of 3
