Posted: Tue Apr 19, 2011 3:25 am |
After a couple mins of driving yesturday my oil warning light came on, stopped check oil level, topped it up. got back in my car and started her up and light went off. few minutes later it came back on.
car feels fine, no drop in revs and is running smoothley, coolant level fine, temp runs as normal.
Checked manual, could be other things but though id ask you lot to see what your thoughts were?
| | ![](images/spacer.gif) |
Posted: Tue Apr 19, 2011 3:36 am |
Has it done many miles? Could be a dodgy oil pressure sensor.
Posted: Tue Apr 19, 2011 3:38 am |
56k
Posted: Tue Apr 19, 2011 5:24 am |
Probably a duff pressure sensor, 1st thing to do is to renew it, easy to change
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Tue Apr 19, 2011 5:29 am |
like others said oils pressure sensor or oil pump as i have seen that happen , light stayed on and then bang engine seized
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Tue Apr 19, 2011 7:39 am |
cheers guys, il check the sensor. anyway of me finding out if its bust without replacing it?
Posted: Tue Apr 19, 2011 10:42 am |
Check the plug and wires too mate.
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Tue Apr 19, 2011 11:31 am |
cu8ey wrote: |
cheers guys, il check the sensor. anyway of me finding out if its bust without replacing it? |
Measure the oil pressure - that needs a oil pressure gauge hooking up.
Just check the wiring / change the oil pressure switch ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Tue Apr 19, 2011 11:44 am |
As a matter of interest, how much oil did you need to use to top up?
