Latest: Andyblue64
Overall: 17123
Online Now [228]:
Visitors: 227
Today: 16654
Total: 98288283
Forums › The Car › 206 Problems › oil light stays on
oil light stays on
cu8ey
PostPosted: Tue Apr 19, 2011 3:25 am Up
After a couple mins of driving yesturday my oil warning light came on, stopped check oil level, topped it up. got back in my car and started her up and light went off. few minutes later it came back on.
car feels fine, no drop in revs and is running smoothley, coolant level fine, temp runs as normal.
Checked manual, could be other things but though id ask you lot to see what your thoughts were?
Moonstone 1.1 Lx
PostPosted: Tue Apr 19, 2011 3:36 am Up
Has it done many miles? Could be a dodgy oil pressure sensor.
cu8ey
PostPosted: Tue Apr 19, 2011 3:38 am Up
56k
Moonstone 1.1 Lx
panason1c
PostPosted: Tue Apr 19, 2011 5:24 am Up
Probably a duff pressure sensor, 1st thing to do is to renew it, easy to change
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
leigh_boy
PostPosted: Tue Apr 19, 2011 5:29 am Up
like others said oils pressure sensor or oil pump as i have seen that happen , light stayed on and then bang engine seized
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
cu8ey
PostPosted: Tue Apr 19, 2011 7:39 am Up
cheers guys, il check the sensor. anyway of me finding out if its bust without replacing it?
Moonstone 1.1 Lx
elcamino
PostPosted: Tue Apr 19, 2011 10:42 am Up
Check the plug and wires too mate.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Tue Apr 19, 2011 11:31 am Up
Measure the oil pressure - that needs a oil pressure gauge hooking up.
Just check the wiring / change the oil pressure switch Wink
PostPosted: Tue Apr 19, 2011 11:44 am Up
As a matter of interest, how much oil did you need to use to top up?
