Posted: Sun May 01, 2011 1:00 pm |
hi everyone, i have a pug 206 LX 1.4 prtrol 52 reg, the problem i have is every few week i get the eml light on, when i put the code reader on it reads OXYGEN SENSOR LOW VOLTAGE LINE 2, i erase the code and it lasts a few weeks before it re appears again, now i have decided to changed the lambda but the car has two sensors, one before the cat and one after the cat, does anyone know what sensor will be causing the the problem, thanks Ads
Posted: Sun May 01, 2011 1:11 pm |
Code should tell you.
Posted: Sun May 01, 2011 1:30 pm |
V9977 wrote: |
Code should tell you. | it didnt give a code, just read oxygen sensor low voltage line 2
Posted: Sun May 01, 2011 1:32 pm |
thats the explanation of the code, it always gives a code lol ...
is it a cheap obd reader? i cant imagine any which dont show you the code though ??
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sun May 01, 2011 1:59 pm |
Sensor 2
Check for the wires are ok, and check the resistance
Also look for a leak near the sensor
If not, sensor will probably be faulty
