Posted: Fri Apr 22, 2011 7:00 am |
Trade Rating: +13
i was at a football match last night. which i drove to....car feeling fine no problems..... after my match i decided i wanted to go home, as you do.
so i started my car, and it started no problem. about 3seconds later i wenr ro go put it in reverse and the car died. to which i thought.....how strange. anyway i decided to leave it for a few seconds as we all know french cars seem to throw a paddy now and again.
so i tried to start it again and it wouldnt start........so i left it for 5 mins, tried again to no joy!
left it for 10mins and still no joy. left it for 20mins and again no joy.
All this time the car was turning over freely and not dying so i concluded it wasnt a battery problem....but i cannot think what the hell is up with it!
i think its either something electrical or something fuel related.
any ideas are welome!!
Posted: Fri Apr 22, 2011 7:12 am |
could you hear the fuel pump at ignition? sounds like the immobilizer became active, odd though.
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Fri Apr 22, 2011 7:15 am |
Fuel cut off switch? Maybe something triggered it?
Posted: Fri Apr 22, 2011 7:20 am |
Trade Rating: +13
wheres the fuel pump located? ill have a listen
Posted: Fri Apr 22, 2011 7:22 am |
Is it turning over faster then normal? ? ?
Wonder if the timing belt has snapped.
Posted: Fri Apr 22, 2011 7:27 am |
Trade Rating: +13
all belts are intact and no, its just turning over the same speed as normal
Posted: Fri Apr 22, 2011 7:28 am |
coopskin wrote: |
all belts are intact |
You have removed the plastic timing belt covers to check?
Posted: Fri Apr 22, 2011 7:33 am |
Trade Rating: +13
mine doesnt have any covers.....unless the one your on about is hidden and not viewable from under the bonnet or underneath the car?
Posted: Fri Apr 22, 2011 7:35 am |
Timing belts are always covered ... not the auxiliary belts that drive the alternator, etc
Posted: Fri Apr 22, 2011 8:32 am |
Trade Rating: +13
Found the problem!!!
The fuel line into the into the spark chamber had come off some how
I put it back on it started first time! Tremendous and thanks to all who input
