Latest: sparrowdclxvi
Overall: 17139
Online Now [119]:
Visitors: 118
Today: 18282
Total: 113466571
Forums › The Car › 206 Problems › AIR CON HELP!!!!!!!!!!
vtrmassive
PostPosted: Mon Apr 25, 2011 3:20 pm Up
i have manual air con on my 2002 206 hdi dturbo , press the button the green light comes on but there is no click from the clutch , all fuses are ok and the air con has been regassed last week and a new pressure sensor has been fitted , when the button is pressed there is no 12v supply to the compressor but when i put a 12v supply to it the compressor clicks in , are there any relays anywhere? i have traced the wires from the pressure sw and compressor back into the car , do they go to the control panel where the heater control knobs are ? and is this the control module or is there a seperate box plaese help im melting
206 HDI - Remapped
PostPosted: Mon Apr 25, 2011 3:48 pm Up
I am going to guess correded wire issue..Engine fan not working either?
PostPosted: Tue Apr 26, 2011 1:43 am Up
Did the aircon system actually work after being regassed & having the new pressure switch fitted?
vtrmassive
PostPosted: Fri May 20, 2011 3:43 pm Up
no still does not work
206 HDI - Remapped
PostPosted: Sat May 21, 2011 2:41 am Up
Who did the regas?
samshah
PostPosted: Sat May 21, 2011 3:04 am Up
Hi there
Most probably a relay on the BSI kit is burnt it is not repaireable. you can use external relay to bring compresssor in service when click turn on the key . you need 2 two relay and 3 meters wires and a electric man to do it .hope to be good this is my expereince
with best wishes
samshah
