Posted: Fri Apr 29, 2011 2:34 am |
My revs on startup in the morming are nearly at 11000 and after a few minutes of driving they drop to just under 9000 and the car doesn't sound as good. Normal?
| | ![](images/spacer.gif) |
| 2001 1.4lx
PrePlexed 5 door. | |
Posted: Fri Apr 29, 2011 2:36 am |
id be worried if they ever went to 9000 ive got a gti180 and it only hits 8000 at the very top ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Fri Apr 29, 2011 2:38 am |
That's completely normally. Car is warming itself up... Every car in the world does this...
Edit: Every fuel injected car does this.. before the hydrogen and electric loving fools come out to play.
Posted: Fri Apr 29, 2011 2:41 am |
drunknmunky wrote: |
id be worried if they ever went to 9000 ive got a gti180 and it only hits 8000 at the very top ![Wink Wink](images/smiles/icon_wink.gif) |
I thought idle was supposed to be 9000 ... Ha.
Ash wrote: |
Edit: Every fuel injected car does this.. before the hydrogen and electric loving fools come out to play. |
Auto choke.
Posted: Fri Apr 29, 2011 3:17 am |
Norvvv wrote: |
I thought idle was supposed to be 9000 ... Ha. |
850rpm
Posted: Fri Apr 29, 2011 4:38 am |
8000? Have you had your limiter raised or something?
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Fri Apr 29, 2011 4:53 am |
CD-vRS wrote: |
Ash wrote: |
Auto choke. |
No such thing on a EFI car.
Posted: Fri Apr 29, 2011 5:02 am |
Edward wrote: |
CD-vRS wrote: |
Ash wrote: |
Auto choke. |
No such thing on a EFI car. |
You know what I mean though.
Posted: Fri Apr 29, 2011 5:43 am |
john_e88 wrote: |
8000? Have you had your limiter raised or something? |
why would i have there's 8000 on the clocks at the top ![Wink Wink](images/smiles/icon_wink.gif)
im unsure as to wether it goes that far i was goin off the highest reading on the clocks which is 8000 ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Fri Apr 29, 2011 6:31 am |
john_e88 wrote: |
im unsure as to wether it goes that far i was goin off the highest reading on the clocks which is 8000 ![Smile Smile](images/smiles/icon_smile.gif) |
They dont go upto that it's just on the dials, you can have it remapped and the limit raised though. Cant remember how high they go before they hit the limiter though
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Fri Apr 29, 2011 6:32 am |
Norvvv wrote: |
My revs on startup in the morming are nearly at 1100 and after a few minutes of driving they drop to just under 900 and the car doesn't sound as good. Normal? |
Fixed the rev's lol
But back on topic, thats normal, when the cars cold it will idle higher, then as it warms up it will drop. When I first start mine it's just over 1000 and after abit of driving drops down to 850rpm ![Smile Smile](images/smiles/icon_smile.gif)
| The Cars:
Posted: Fri Apr 29, 2011 6:35 am |
Ste206 wrote: |
john_e88 wrote: |
They dont go upto that it's just on the dials, you can have it remapped and the limit raised though. Cant remember how high they go before they hit the limiter though |
ahhh i see ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Fri Apr 29, 2011 7:13 am |
Ste206 wrote: |
Norvvv wrote: |
Fixed the rev's lol
But back on topic, thats normal, when the cars cold it will idle higher, then as it warms up it will drop. When I first start mine it's just over 1000 and after abit of driving drops down to 850rpm ![Smile Smile](images/smiles/icon_smile.gif) |
Cheers ha.
