Online Now [1233]:
Visitors: 1232
Today: 103535
Total: 150412285
Forums › The Car › 206 Problems › knocking tapping noise
hampshire1
PostPosted: Mon May 02, 2011 4:08 pm Up
206 1.4 hdi 2003. oil fine. knocking or tapping loudly on tick over 800 rpm
from cam belt side of engine. at 1000 + rpm the noise goes, the car runs really good. just noisey on tickover. normal fuel consumption. 100,000 miles on clock. any ideas? cam belt change due to be booked in will this help?
206 1.4 hdi 2003
Antknee
PostPosted: Mon May 02, 2011 4:19 pm Up
Does it sound louder than normal when its idling?
If so... oh dear, mine did this 2 weeks ago and it was the timing belt tensioner had exploded and the bottom pulley had just about gone too
Same car too and same year
Edit: also it was booked in for a timing belt change the following week and was on 106k
PostPosted: Mon May 02, 2011 4:25 pm Up
what oil diod you use and when is the last oil change?
sometime poor oil quality will give you tapping noise.
hampshire1
PostPosted: Mon May 02, 2011 4:31 pm Up
not sure what oil, not expensive though. maybe oil and filter change will sort it out..
206 1.4 hdi 2003
hampshire1
PostPosted: Mon May 02, 2011 4:32 pm Up
what oil and grade would be best for it?
206 1.4 hdi 2003
hampshire1
PostPosted: Mon May 02, 2011 4:35 pm Up
the noise sounds like its coming from top of engine and goes over 1000 rpm.
206 1.4 hdi 2003
santos2001uk
PostPosted: Tue May 03, 2011 2:31 pm Up
mine does the same. been told its a leaky injector. if you listen you can hear it. mine sounds like a steam train but keeps on going. even at 171k miles.. dont worry but if you fix it let us know. think iv read the injectors are very hard to remove so iv not even considered trying to fix it yet
Praise the lowered
